M12 maritimo
  • bonewar
    • 587
    #121
    J.m.
    Thanks for the picture.
    Mate i have 2 in hull pickups in 1 of me SV27.
    Down the pond ,1 of the water tubes let go , and with in 2 laps of about 100m
    the boat was full of water. I now glue the water tubes to the nipples.
    Safer that way!!
    No need for the external water pickups as the in hull pickups work very well.
    Also i like to keep the transom of my boats very clean.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • old guy
      • 710
      #122
      hows that trap door coming along lol
      Old guy
      • bonewar
        • 587
        #123
        Old guy,
        Thanks for the idea on the tunnel wing.
        Its just the thing i needed to finish off the wing.
        Sneak peak!!!
        Bonewar
        • bonewar
          • 587
          #124
          Esc , capacitor wiring
          OK ,
          Got busy today,
          First off, I soldered the caps to some 10awg wire .
          I've changed the size of the caps(2200uf) after talking to Castle.
          Better to use this size for my application.
          Then i soldered the rest of the wires to some new lengths of 12awg.
          Then i added the caps to the wires .
          I will run one set of +- down each side of the ESC for my lipo connection.
          Added the motor connectors also.
          Just waiting on the strut , Then i will glass in the motor mount and add the drive line
          to this beast.
          Bonewar
          • Jeff Wohlt
            • 2740
            #125
            I think I found you the strut you need to fit that beast. I will pm you.
            www.rcraceboat.com
            jwohlt5362@yahoo.com
            • bonewar
              • 587
              #126
              Thats great news Jeff,
              It's the last piece of the puzzle.
              And i am sort of at a stand still with out it.
              I couldn't resist your bearing strut for this project.
              I FINALLY finished the ESC connectors .
              Took me a hole day to sort it out.
              Bonewar
              • HYDROJERRY
                • Jan 2010
                • 2709
                #127
                the soldering you did is super nice excilent work man
                • Jeff Wohlt
                  • 2740
                  #128
                  No doubt....what watt iron will do that big stuff?
                  www.rcraceboat.com
                  • bonewar
                    • 587
                    #129
                    Thanks Jerry,
                    Jeff,
                    I use 2 soldering irons.
                    They are made be WELLER, 1 is a 40w iron and the other is a 80w iron.
                    I use the 80w iron on the big stuff and the 40w on the small jobs.
                    Bonewar
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      #130
                      Man i use a Weller 140/100W and cant do it anywhere near how you do and im a welder at work so i would say you got some crazy skills but anyway nice work
                      • obrien008
                        • Sep 2009
                        • 141
                        #131
                        Nice work, that thing is looking sick, im having trouble heating up my parallel connectors for my esc too, guess im gonna have to go get a bigger iron aswell, but keep up the good work bro
                        • bonewar
                          • 587
                          #132
                          Jerry,
                          The Weller iron i'm using is a 80W 240V, i think they get up to 900F.
                          That is enough heat to solder most joins.
                          No trick to getting a good join.
                          I apply a little flux to clean the area , get the wire real hot and apply the solder close to the tip, that way i know it's flowing throw the wire.
                          Wet sponge to cool the job.
                          Then i file the excess solder off for the prefect join. Also a clean solder tip helps.
                          Rubber paint to seal the job. Done!!
                          Thanks Obrien,
                          Yer i think its going to turn out pretty sick to mate.
                          Bonewar
                          • HYDROJERRY
                            • Jan 2010
                            • 2709
                            #133
                            Maybe thats it i havent been useing the flux,,,
                            • bonewar
                              • 587
                              #134
                              Update
                              OK,
                              This is where I'm up to with the build.
                              I've started to prep the side of the boat and added a bigger chime.
                              The extended chime is for turning and looks ,
                              With these Maritimo's they tend to slide out in a corner when trying to apply power.
                              This is why i have added the bigger chime , to help with the slide out affect at speed.
                              Also added a very small 7 volt fan up front for the esc .
                              Just waiting on my strut and then i can finish the back of the boat and paint her.
                              Bonewar
                              • tiqueman
                                • Jul 2009
                                • 5866
                                #135
                                Looks awesome Rick! Doing the chine like that doesnt cause it to roll in a turn? I know that works on V hulls, just never seen anyone do it on a cat? Did a nice job on it though, as usual.
