M12 maritimo
  • bonewar
    • 587
    #76
    DISAR,
    Thanks mate .Love the carbon fiber look. I've had this cat plan out for a long time. More goodies to come yet!!
    Rumdog,
    Mate i'm going to start with 10s1p with a octura x646 barr cut.
    My plan is to get the cat running fast and stable on the 10s.
    Then i will go to the 12s1p and probably a ABC 4518/2 or ABC 4217/3.
    Also this is the time i will plug in the gyro operated tunnel flap.
    I've got myself some real nice props for this project ABC 4518/3 - ABC 4718/3.
    I don't want to go over 47mm in dia on the props , Because the Maritimo will show very bad prop walk issue the bigger the prop , Which will also prevent the hull getting to 80+mph.
    Wolf IV
    Wolf I cut out the foam to go into the spoonsons and the front of the cat.
    Then i made up the bulkhead setup with foam added.
    I weighed both setups and the carbon bulkhead is lighter then the solid foam setup.
    Also i needed a place to put the hydra.
    Buy the time i've glass the bulkhead in, it should come out around the same weight as the solid foam.
    Only gain here is strength.
    Bonewar
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
    • bonewar
      • 587
      #77
      Motor mount
      Finished the carbon mount for the CNC motor mount to sit on.
      I think it has come out real nice.
      It will be epoxied to the tunnel floor.
      Bonewar
      • amo123
        • Jul 2009
        • 63
        #78
        holy moly this build is freakin awesome! for the cf sheet you made....is there anything you put on the glass to get it to release? if so what is your method?
        savage 4.6 - blackjack 26 - e-revo - HOTR 32" Apparition - blade cp - blade sr - trex 450 -
        • bonewar
          • 587
          #79
          Amo123,
          Here is a link for you. Should explain everything you need.
          http://forums.offshoreelectrics.com/...ad.php?t=13126.
          Have a look at post-31 2nd page .
          Cheers Bonewar
          • HYDROJERRY
            • Jan 2010
            • 2709
            #80
            bonewar, that mount is SUPERSWEET looks like a starwars tie fighter, you made it? im doing a skunkworks well buying parts not started building yet, would you make and sell those, looks like has the angle mine will need, very nice work...
            • bonewar
              • 587
              #81
              Hydrojerry,
              Mate the motor mount is made by Peter Zicha.
              Have a look here.
              http://forums.offshoreelectrics.com/...ad.php?t=10698.
              I bet if you talk to Peter you guys could come up with something.
              I have just modified the mount with some carbon 3mm plate
              to get the right angle.
              Cheers Bonewar
              • HYDROJERRY
                • Jan 2010
                • 2709
                #82
                Thanks for the info brother i will check him out..
                • bonewar
                  • 587
                  #83
                  Update Tunnel Wing
                  I've been busy building the new tunnel wing assemble.
                  The carbon plate i made has come in very handy.
                  Just hope it works as good as it looks!!
                  Prof in the testing!!
                  And version 1 of the wing.. Deleted
                  Bonewar
                  • HYDROJERRY
                    • Jan 2010
                    • 2709
                    #84
                    Looks great hope it works good...
                    • tiqueman
                      • Jul 2009
                      • 5866
                      #85
                      Lookin good there Rick... Really good!
                      • Jeff Wohlt
                        • 2740
                        #86
                        Rick, Got your stubs and cable in the mail yesterday.
                        www.rcraceboat.com
                        jwohlt5362@yahoo.com
                        • bonewar
                          • 587
                          #87
                          Excellent Jeff,
                          Looking forward to getting them back all silver soldered and pretty.
                          Give us a text when you have finished them.
                          Thanks mate .
                          Rick
                          • Jeff Wohlt
                            • 2740
                            #88
                            Do you want one made longer on the stub as you spoke about in your letter?
                            I will see if I can get the other one apart. All the same length of cable/stub?
                            www.rcraceboat.com
                            • bonewar
                              • 587
                              #89
                              Update spark suppression
                              With the lipo set up on this cat i will be running 10 - 12 (37v-44.4v) cell lipos.
                              The extra large capacitors i'm using on the Hydra HV 240 will INCREASE the sparking affect when joining the ESC to the lipo's.
                              So to stop this happening !!! Here is a solution to fix the problem and to stop that nasty spark from causing any problems. PIC 123
                              The Maritimo she's all cut up.
                              Just about to start rebuilding here.
                              Going to strengthen the area around the transom tunnel wing and strut mount.
                              Should come out real nice.
                              Next update when i have done something!!
                              Bonewar
                              • DISAR
                                • 1137
                                #90
                                Great job. The text for the resistors is for MGM controllers, for Hydras Castle recommends 1Ω resistor 2-3 watts. I am using 1Ω resistor 5watts with HV240, so far so good. no sparks and everything works ok. If using higher resistors such as the 60 Ω may cause the hydra not to arm properly, if i remember well.
                                If it arms ok with the 60 then no problem, but I think mine did not. then I put the 1Ω and OK
                                http://www.rcfastboats.com/
