Seaducer FE-38
  • FE_Chris
    • Jun 2007
    • 906
    #46
    That is one nice boat doug. So when are you gonna put some speed on that hull? Joking man. That thing hauls.
    I have only ever seen one other seaducer run. It was nitro. The hull looked to handle and ride fantasticly. And you gotta love that seaducer look. I don't think anyone else makes hulls that look quite like them.
    What kind of run times you get with that thing? What kind of cells you running?
    Fast Electric and Fast Ford's / V8 Mustang Enthusiast
    • Doug Smock
      • 5359
      #47
      Thanks Chris,
      With the current setup I'm thinking the runtimes will be approx 2.5 to 3 min., keeping it safe. I'm running 4x3s Neu energy 25/50 4900 packs for 6sp2.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • FE_Chris
        • Jun 2007
        • 906
        #48
        Very nice setup Doug. Those packs are out of my budget, but they sure sound nice! Kinda makes me want a seaducer....maybe I figure something out for the winter as a build. Bad thing is, I hardly see them on ebay for sale.
        • LuckyDuc
          Team Ducati Racing
          • Dec 2008
          • 1058
          #49
          Hey Doug,
          I would like to do an "irrigated tube" setup as well, and I was wondering if you ran the teflon liner without a stuffing tube directly into the strut. If so, was there a lot of slop between the teflon liner and the front of the strut. What size liner and flex cable did you use?
          Thanks.
          • Darin Jordan
            • 9446
            #50
            Originally posted by LuckyDuc View Post
            Hey Doug,
            Thanks.
            I use a floating stuffing tube in all my monos these days... Here is a drawing that shows how I did it in my 32" Wildthing P-Mono... .187 cable... can't recall the exact size of the stuffing tube and teflon, but the outter piece of brass that houses it all is 3/4" I believe...
            Darin E. Jordan - Renton, WA
            • LuckyDuc
              Team Ducati Racing
              • Dec 2008
              • 1058
              #51
              Thanks for the pic Darin. This is my first irrigated floating stuffing tube attempt.
              I'm using a Non-stinger style strut, but if I understand your diagram correctly... just the teflon liner and cable is exiting the hull and entering the strut?
              • Darin Jordan
                • 9446
                #52
                Here is pic of another boat with a standard strut... Yes, in this case, I'm using a wire drive, so I just ran the teflon into the strut. On a cable, I run the entire brass stuffing tube (inner one) into the strut....
                • Gerwin Brommer
                  • Dec 2008
                  • 928
                  #53
                  Doug.
                  Something wrong with the video-link ? All I see is a clock ?
                  • blakybob
                    • 131
                    #54
                    Strange but worthy this subject should get resurected from 2007, I was just talking to Doug about this Sunday at the pond in Atlanta holding a piece of rubber 1/2" conduit in my hand. Darin, what did you use for the tube part and what size is it? Looks 3/8"ish.
                    Blake
                    • Darin Jordan
                      • 9446
                      #55
                      Blake
                      The boat in the second picture is an N1-Mono, so it's only 22" and it uses a 1/16" (.061") wiredrive, so the ID of the outter tube doesn't need to be very big... I think you are right... it's 3/8" or 11/32 or so...
                      The P-Mono in the previous pictures is around 3/4" or so...
                      Won't build another mono that doesn't have a flooded shaft.... Just works!
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 1058
                        #56
                        I wonder how far back I need to float a piece of 1/4" tube to get enough flex/ movement at the strut... 6" from the transom? More?
                        • Doug Smock
                          • 5359
                          #57
                          Originally posted by Gerwin Brommer View Post
                          Doug.
                          Hi Gerwin, the last video I uploaded was the clock.Try this link.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Doug Smock
                            • 5359
                            #58
                            Since this build I have done the same thing. When I started SAWing this boat I realized the teflon had to go. Shortly after that I had to get away from my FM radio, and in came the 2.4. My FM radio didn't like the cable in brass at those high rpms.
                            I have a 42" mono I'm getting ready to setup. Should be interesting, I'll be running a 1/4" cable and a offset strut. I'll post some pics when I get to that point.
                            Doug
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
