Seaducer FE-38
  • Doug Smock
    • 5359
    Seaducer FE-38
    I haven't posted a build thread in a long time, and never here, so I thought I would share this one.
    It's a 38" Seaducer that I am going to power with a Neu 1521-1Y and 6s 2p Neu Energy 25/50 4900s.
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
  • SJFE
    • 4867
    Nice looking hull Doug. What do you plan for hardware? Also what do you have in mind for a hatch?
    • hkusp45
      • 308
      I like the seaducer hulls. I too am interrested in the hatch that you will be using....
      NAMBA #581
      Q mono NAMBA record holder
      'REMEMBER SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO SHOOT THEM'
      • Doug Smock
        • 5359
        Thanks guys,
        Seaducer hardware and a clear lexan hatch for now.
        I plan on making hatches for my 33 and this one at some point. Maybe this winter.
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
          • 7512
          Looks nice, One guy in our club has a nitro version that never seems to run well, I can't wait to show him your build so he can see how it should run:D
          • Doug Smock
            • 5359
            Well,
            It's hard to see but the floatation is in. It goes from the keel up to the deck, all the way to the bow. I used Gorilla glue to keep it there just in case of a catostrophic hull failure. Hopefully........... the money will stay with the floatation.
            It also strenghtens the front of the hull.
            The hardware is installed and the elongated hole for the drive is in.
            This is my first attempt at a "irrigated shaft alley". A small portion of the keel at the transom will be flooded, but this will allow plenty of room for strut adjustment.
            Doug
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Doug Smock
              • 5359
              Motor mount
              This is a long heavy motor so I made this two piece aluminum motor mount. The inside of the ring is covered with large fuel tubing split lengthwise. The motor fits good and snug.:)
              I installed 6-32 blind nuts in the 1/8" ply base plate to attach the motor mount, and put some stringers under the plate to give it alot of surface to glue to. The marked center section will be glassed to the hull as well.
              If it ever comes loose, I'll allways think it shouldn't have.LOL
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • SJFE
                • 4867
                Excellent work on the mount. I may look you up for one of them :).
                • Doug Smock
                  • 5359
                  Thanks Tom,
                  I don't own a mill, YET.
                  I made that with a drill press, files, and a $14.00 brake from Harbor Freight.
                  It took some time but I'm happy with the results.:)
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Doozie870
                    • 970
                    Thanks for the build! its nice to see how the big boys do it!
                    One thing I have trouble with, is making the initial marks on the hull for the hardware installation, is there a trick or a template that you make?
                    • Stealth Assassin
                      • 610
                      Originally posted by D.Smock View Post
                      Thanks Tom,
                      Doug
                      Killer Idea with the tubing also how do you seal off the elongated hole for the stuffing tube?
                      • Doug Smock
                        • 5359
                        Big boys, LOL. Thanks man, but I'm just a seasoned rookie.
                        I just tape up the transom, find the centerline and go from there. Measure and check everything twice and start drilling.
                        As far as setup, I went with Seaducers instructions on this one. Jerry knows his Monos!!!!!
                        Doug
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • Doug Smock
                          • 5359
                          I'll set two bulkheads to support the tube and then box in the shaft log with ply, glass and epoxy.
                          I'll try to post some GOOD pics of it. I'm almost at a stand still until the cells arrive. I want to be able to run 1 or 2p in this boat
                          ( I don't know which way the rules are going), so the motor placement is going to be critical.
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Stealth Assassin
                            • 610
                            I bought a ac lazer 40 I was thinking about setting up this way...
                            • skeeler
                              • Jul 2007
                              • 208
                              That's some nice work, Doug. Please keep us up-to-date. By the way, where can a person learn about forming fiberglass?
                              Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
                              '09 Miata.
                              Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
