SC 32 FG build
  • RandyatBBY
    • 3943
    SC 32 FG build
    I am in the process of building a boat for a friend It is comming out sorta cool so I thought I would share the progress.
    The hardware on the business end.
    Randy
    BBY Racing
  • RandyatBBY
    • 3943
    One of my new motor mounts and the dual ball bearing setup. I have devised a way that both bearings come out of the strut to be repacked upon re-install. This saves the bearings from corrosion and early failure.
    Randy
    BBY Racing
    • RandyatBBY
      • 3943
      A little more progress on the new motor mount I tested this mount at the 2009 SAW's pushed low 60ties on a new boat worked great!
      Randy
      BBY Racing
      • NativePaul
        Greased Weasel
        • 2770
        Nice Randy, what's the diameter of the hole in the rear support for a 15 series Neu and split cooling tube cushion?
        • RandyatBBY
          • 3943
          It is a 1 5/8 with a little hand work to fine fit. Motor mount kit for under $20.00 bucks!
          Randy
          BBY Racing
          • RandyatBBY
            • 3943
            Glued in the runners.
            Stuffing tube built with water cooling.
            Flex shaft and servo mount installed.
            Boat is ready to paint and install electronics. All that is left for me to do is trim out the hatch and I am done with my part.
            Randy
            BBY Racing
