New catamaran project
  • Rumdog
    • 6453
    #91
    Try an octura m445 prop.
    • Alfa Spirit
      • 2131
      #92
      Now water cooling is ok, I will waterproof the HiModel GX 200 with silicon
      • CornelP
        • 745
        #93
        That is more than enough... Have you checked if all FETs touch the plate? It is a common problem with those... If not, sand them a bit with fine grit and you should be ok. Do not rely only on the thermal paste, it works better in very thin films, make it thicker and it's bad. The last thing you want is to have FETs at different temperatures, quite erratic...
        • ozzie-crawl
          • Sep 2008
          • 2865
          #94
          looks like he is using thermal tape, works really well and also helps hold the plate in place and doesnt slide around like the paste. some people say the paste is better but i have seen data proving other wise, also if the boat gets dunked a few times the paste can wash out and it can also dry out
          • Alfa Spirit
            • 2131
            #95
            Yes, I use 3M thermal tape, all FETs make contact with the tape
            Is Rubson silicon glue good to waterproof the ESC?
            • Alfa Spirit
              • 2131
              #96
              I made the HiModel GX 200A ESC water cooled and wtaterproof with ETTI plate
              Heat shrink tube and it will be okay Let me know what you think
              • Simon.O.
                • 1521
                #97
                Dang ugly, but if it is waterproof then that is important. I am about to the same to Mystery 200 with the Etti plate. I am looking at using clear silicone sealant, it is cheap and I have loads of it.
                • ozzie-crawl
                  • Sep 2008
                  • 2865
                  #98
                  i have some of this still not sure if i should try it.mite still conformal coat it first
                  i rarely get more than a drop or 2 in my boats but accidents happen
                  • Alfa Spirit
                    • 2131
                    #99
                    Yeah
                    That' s why I need to put heat shrink tube .... coulored or black
                    • Alfa Spirit
                      • 2131
                      #100
                      Now it looks much better
                      • Alfa Spirit
                        • 2131
                        #101
                        • lomdel
                          • 708
                          #102
                          Now it looks much better...
                          ...but is it art?
                          (sorry, I couldn't resist.)
                          • bigpapa
                            • Apr 2009
                            • 2330
                            #103
                            looks awsome so far, good job...................
                            THUNDER TIGER OUTLAW,THUNDER TIGER BANDIT
                            CARBON FIBER MINICAT HYDRO,MINICAT HYDRO,PROBOAT MISS GEICO,SKUNKWORKS 32" CAT TWIN, H@M VIPER TURBINE ---JEFF WOHLT WIRE DRIVES
                            • Alfa Spirit
                              • 2131
                              #104
                              I' ve got my first Li-Po batteries set, I' m waiting for charger and Spektrum DX 2S DSM radio
                              Capacity:4500mAh
                              Continuous discharge rate: 35C
                              Burst Rate :40C
                              Voltage: 11.1V
                              Cells : 3
                              Size : 133x 42 x 24mm
                              Net Weight: 310g
                              Price : 66 € / 96 US$ / 64 £ for 2 pces including shipping
                              • KillerDave
                                • 370
                                #105
                                Capacity:4500mAh
                                Burst Rate :40C
                                Voltage: 11.1V
                                Cells : 3
                                Net Weight: 310g
                                Wow! That is a great price, Where did you get them from?
                                HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
