New catamaran project
  • winner
    • 45
    #76
    wow man the boat looks great! and dang that motor is massive!
    A common mistake that people make when trying to design something completely foolproof was to underestimate the ingenuity of complete fools. -Douglas Adams
    • norbique
      • 356
      #77
      how much was the etti cooling including shipping?
      Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
      - Mark Twain
      • bustitup
        • 3071
        #78
        $13 plus shipping which i think is $9
        http://www.offshoreelectrics.com/pro...prod=etti-a044
        • Alfa Spirit
          • 2131
          #79
          Originally posted by Alfa Spirit View Post
          I bought an ETTI water cooling plate for my HiModel GX 200
          I paid 14 €uro including shipping cost to France, here' s the link
          This is the large sized
          http://cgi.ebay.fr/ETTI-Wasserkuehlu...item43956f2d90
          • Alfa Spirit
            • 2131
            #80
            Thanks, All parts: hull, ESC, motor, .... are cheap but are matched
            • Alfa Spirit
              • 2131
              #81
              Hi,
              I' m not sure that flex/shat coupling will be strong enough.
              I think to reinforce the end of the square flex cable with strong glue Is it a good idea? Thanks
              • cugino
                • 136
                #82
                Prop
                Hi Alfa Spirit,
                your project is very impressive for me. Im going to build this cat either.
                On picture above i can see very nice prop in fitted in graupner DD. As i remeber, graupners DD has outer dia. 10mm and to props seem to be perfectly aligned with DD. Octura has about 8mm hub dia. So i prefer props like yours. Where does your prop come from?
                Thanks, Cugi.
                -= MHZ Shockwave - MHZ Micro Fountain - MHZ Cougar 2 - "Orange cat" =-
                http://olaf.webz.cz
                • elvish
                  • 125
                  #83
                  Hi,
                  Now I' m working for nice paint job I will do the paint job before components assembly
                  it will hold just fine, glue will not add to its strenght ,
                  • Alfa Spirit
                    • 2131
                    #84
                    Ok, thanks Elvish
                    The aluminium propeller is a USA brand may be AMPS or something like that. No brand on the prop, only 2029
                    My cat project is a cheap RTB and I' m pretty sure it will rock
                    • Alfa Spirit
                      • 2131
                      #85
                      Hi,
                      I want to order propellers for my cat' I hope you can help me.
                      Cat' HOTR, 6S batteries and motor 540 XL 1510 RPM per Volt
                      Thanks
                      • Alfa Spirit
                        • 2131
                        #86
                        OCTURA X440/3 or X447/3 ?
                        Which one will be the best for my setup? I really want to order 3 blades propeller
                        Thanks
                        • KillerDave
                          • 370
                          #87
                          I understand what you mean.
                          I will install a brass tube 4mm inside and 5mm outside, approx. 15mm long. Like this the shaft won' t move, only a small amount of play
                          Hi,
                          I have just modded my original TFL strut because I might be getting the dual motor set from e-bay, The problem with this is that it runs 4mm stingers and I want to use 3/16" prop's...
                          I turned down a piece of oil-lite brass 4mmI/D and 4.762 O/D. It's a lovely snug fit now and runs true.
                          I think this is the way to go if you want to use 3/16 props on any 4mm shaft.... IMO!!
                          HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
                          • Alfa Spirit
                            • 2131
                            #88
                            Hello guys, I' ve found an interesting product from 3M : Thermally conductive pads. It' s not expensive , very easy to work with. Advice please
                            3M Thermally conductive
                            • norbique
                              • 356
                              #89
                              Very interesting! I'm just modding a 100A mystery ESC. I sanded the FETs flat and I will glue the heat-sink on them with a thin layer of JB Weld.
                              - Mark Twain
                              • Alfa Spirit
                                • 2131
                                #90
                                I' m waiting for 2 pads thermally conductive from 3M, price is 4 € / piece :
                                Here are the parts for direction channel Very clean.
