Hpr06
  • malibu1
    • Sep 2009
    • 74
    #181
    I am really wondering how all this equipment is going to fit in the hull and not make it sink! The water jackets on the 1527's are going to be a tight fit. I think I may have to make my own motor mounts...
    • westbeach
      OSE Rocks!
      • 969
      #182
      You can get pre-cut C/F motor mounting plates and servo mounts together with the transom doublers for your HPR from AE-Carbontec. Email Andreas. He is a good guy to deal with. I bought my parts for my first HPR06 from him.
      HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
      • vvviivvv
        • 1148
        #183
        mounting holes are probs diff, there's + hanspeters are designed around the 19"" series lehner motors so i was told... mounting my motors tomorro both of the drivers are now attached. orderd a eagletree with gps and some thunder power g4 30 / 60 c batts didn't want to chance china lipos
        Uk SAW record holder
        • westbeach
          OSE Rocks!
          • 969
          #184
          Nope! I have AE-Carbontec's motor mount and I had my Neu 1521's mounted in my HPR.
          • vvviivvv
            • 1148
            #185
            1521 and 1527 have same mounting holes so maybe its length wise? since u have to kinda angle them to get the drives to line up...?
            • westbeach
              OSE Rocks!
              • 969
              #186
              The 1527 are a longer can than the 1521's. But there is lots of room to mount either one. The motor mount plate has to be angled down and inboard toward the stuff tube. I would suggest finding a solid aluminum rod to help position the motor plates. Mock setup the motor,collet and alum. rod and the stuff tube. I would then permanently epoxy the stuff tube into position first, before the motor plate.
              • malibu1
                • Sep 2009
                • 74
                #187
                I have the motormounts from AE-Carbontec and also the motor mounts from HP. HP said his mounts are for the Lehner motors. I can put the HP & AE mounts next to each other and they are identical. I am almost positive they come from the same CNC machine. Mounting holes match the 1527's perfectly. Its just going to be a tight fit using these mounts, pointed inboard and down and have the water jackets on them. Tight, but I think it may just fit. Have not done a mach-up yet.
                • vvviivvv
                  • 1148
                  #188
                  actually, are either of you thinking about sanding the tops of the mounts a little bit because mine push the deck up in the area im mounting them...
                  • toysRme
                    • Jul 2009
                    • 79
                    #189
                    Are you running counter rotating props or both the same way??
                    Im going to run Neu 1518 on 5S so i can race in the 10S class here in Australia.
                    What speeds do you expect from your 1521 and 1527 setups?????
                    STUFF NITRO GO LIPO FASTELECTRICS.COM
                    OFF-SHORE-ELECTRICS.COM
                    INVENTOR OF LITHIUM CELLS:bowdow
                    • vvviivvv
                      • 1148
                      #190
                      about 80 - 85 on 6s maybe 95 on 7s? i aint 100% but i got some meaty props
                      with a 1521 1Y
                      • malibu1
                        • Sep 2009
                        • 74
                        #191
                        V, I will need to re-shape the motor mounts a little bit. Also, the transom doublers need to be re-shaped for a perfect fit. I may trace out some new ones once I get some C/F.
                        I am not sure what kind of speeds mine will run. I am going to run 6S to start. Not sure on props yet. Was thinking X442 & X442R.
                        • vvviivvv
                          • 1148
                          #192
                          made my own doublers too
                          u will need atleast x447 with 1527's o.o probs 52mm...
                          • toysRme
                            • Jul 2009
                            • 79
                            #193
                            When you say 80-85 , You mean M.P.H ???
                            • Tuslow1
                              • 154
                              #194
                              vvvviivvv and malibu1, are you guys getting stingy with pics?
                              OK, You Go First!!!
                              • vvviivvv
                                • 1148
                                #195
                                yeah they been clocked at 128mph...
                                its got pen all over it i will tonight tho
