For andym
This topic is closed.
  • andym
    More Go Than Show Prop Co
    • 2454
    #421
    Douggie I think the Scots have them stuffed mate!!!! Great laugh
    • Flying Scotsman
      Fast Electric Adict!
      • 5195
      #422
      Yeah, but who will win. I will put my bet on Dolly
      Douggie
      • Xzessperated
        • Apr 2008
        • 3063
        #423
        Andy,
        I have started cleaning up after the fire in my Xzess 2. Today I put new heatshrink on the motor wires. One had the heatshrink off all the way inside the can so I had to carefully feed some into the can entrance hole so that it does not short against the can. Two of the leads had the 5.5mm connectors burned off so I replaced those. I tested the Neu after that and it sounds good to me. An on water test will tell the story I guess.
        Below are some pictures of the hull damage. There is virtually no damage to the main hull but the hatch cover needs a bit of work. The heat has pulled it out of shape a bit and I am not sure I can fix that as it would take heat to do it I guess. It is not a big problem as the hockey tape will pull it back into place or I can use the cover from Liquid Insanity.
        Below you can see where the real damage is done to the hatch cover. The darkest area is just fiberglass cloth but I will leave it as it is quite strong. I will add some more cloth over the top and then patch it all up with epoxy. Some sanding and a bit of paint and it will look like new, no on second thoughts, it will look like I repaired it.
        • Xzessperated
          • Apr 2008
          • 3063
          #424
          Andy,
          I found an MGM ComPro 12024 - 3s/WP Z series RB esc at the bottom of my parts box. The name is bigger than the esc. I got it quite sometime ago and never used it. I put some connectors on it and plugged it into the 1515 1.5y and it works. I will run it on small props to start with as I know nothing about the quality of these controllers. All I can say is it looks like good quality and was priced like good quality at the time of purchase. It is rated at 120 amps and is water cooled. I will let you know how it goes. If that fails I think it is time to buy one of the CC 240's.
          • andym
            • 2454
            #425
            *!***!***!***!** Paddy when you have a fry up you sure do burn things don't you? Good to here you are using that glass I sent you, use a smear of stop putty before you sand and with luck you will not see anything amiss whaen repaired.
            As far as that esc is concerned I know nothing of them but heck give it a go, this one mite just blow up instead of starting an inferno!
            Hey can you forward Chuck that pic, it is unfinished but anything to keep him happy.
            Cheers Andy
            • Xzessperated
              • Apr 2008
              • 3063
              #426
              Cheers Andy
              Jan might read about the ComPro controller and know something about them. I have cleaned things up quite well now with circuit board cleaner and I can see all the seriously damaged parts.
              Chuck has the picture in his email.
              • Flying Scotsman
                • 5195
                #427
                Christ, Paddy you need a new saviour ???
                Douggie
                • Xzessperated
                  • Apr 2008
                  • 3063
                  #428
                  Douggie
                  As Mel would say "A certain race of people killed the last one"
                  Oh well Douggie if I play with fire I will get burned. I know with most of my setups that I am playing with fire but I have 20 years left to live (I guess) and I want some memories for the years I spend in a wheel chair. With my luck I will get Alzheimer’s and the memories will be wasted.
                  Happy Easter to you and yours Douggie.
                  • andym
                    • 2454
                    #429
                    I have been told recently to watch my P's & q"s Well as this thread is addressed to me GET F222222D, I will get sober soon and Dick2222222 look out I am coming for you Lad.
                    • Xzessperated
                      • Apr 2008
                      • 3063
                      #430
                      Oh dear
                      • Flying Scotsman
                        • 5195
                        #431
                        Andy, your P**s and quintessence has been duly noted. Paddy, Chuck and Danny, I think he might have to dust off his dictionary, if he has one, for the true meanning.
                        Douggie
                        • egneg
                          • 4759
                          #432
                          Andy this is for you.
                          IMPBA 20481S D-12
                          • Flying Scotsman
                            • 5195
                            #433
                            Chuck, you have caught him on a good day...brilliant.... I think I just wet my pants. Woops sorry the floor as the big boys do not wear?
                            Plus a piece of great http://www.youtube.com/watch?v=0V0OxkKXG-M
                            Douggie
                            • Flying Scotsman
                              • 5195
                              #434
                              We are all on line this could be interesting
                              Douggie
                              • Flying Scotsman
                                • 5195
                                #435
                                Chuck, I knew it. The Aussies now have to make a plan Paddy are you on the phone, as we are about to be killed
                                Douggie
