Power supplies 12v or 24v plug and play
  • JRPLANE
    • Nov 2011
    • 117
    12volt 47 amp 564 watt,
    24volt 47 amp 1130 watt.
    I am using two in series for 24v on my lab 8, they are very stable, rock solid,
    They are set up ready to go with 4mm outlets and power cords.
    Heres a close up of the bussiness end of the power supply.
    You can see the 24v model is wrapped in black, comes with jumper to allow 24V. as you can see you can use 2-12v and 1-24v at the same time. 2-12v top row , 24v bottom row, or remove the jumper and you have 4-12v outlets. With the jumper in place you also can use the out two far out side connections for two 24V outputs. These power supplies are rated at 47 amps. I have personally abused my test setup, just to see where the fail point is. I have had my Lab 8 with 6-5000 3S @ full 40 amp charge and a cellpro 10 with 2-5S running wide open. I'm still using this power supply with no problem. Just because I did this for testing purposes,,,,,,,,,
    I DO NOT RECOMMEND GOING OVER RATED OUTPUT!!!
    Singles are 12v and white $55 shipped
    Doubles are 12v and 24v and black $110 shipped
    These are 100% ready to use. Plug and play
    I will ship out of the US,
    Check out the thread on RCG
    I have sold many there!
  • JRPLANE
    • Nov 2011
    • 117
    Just a few more pics
    • Clueless1
      • May 2011
      • 301
      Do you have any 24v power supplies available?
      • JRPLANE
        • Nov 2011
        • 117
        Yes sir ready to ship
        • Clueless1
          • May 2011
          • 301
          Any recalls yet? ;-) I'll pay pal you and provide shipping info in the morning.
          Thanks,
          Todd
          • JRPLANE
            • Nov 2011
            • 117
            No recalls at all , these things were made to run 24/7-365, the way we rc'ers use them they should last two life times.
            Just paypal jrplane@hotmail.com, i can ship it in the mourning
            • Chrisg81983
              • Jul 2011
              • 1585
              They come with power cord I am interested in getting a double what have you ran with a single unit
              • Anbjorn
                • Apr 2009
                • 255
                Hi,
                I can not see it mentioned here. What is the input voltage and frequency?
                110/60Hz or 230/50Hz?
                Maybe interested in two 24V units that I can parallel into + 90A @ 24V
                Anbjørn
                Anbjørn
                • JRPLANE
                  • Nov 2011
                  • 117
                  Yes they come with a power cord. Look up in the ad, I use a double with a lab 8 all the time.
                  Here is the link to RCG with feedback from the people there,
                  • JRPLANE
                    • Nov 2011
                    • 117
                    Anbjorn, I only sold one oversea's mostly because of the price of shipping.
                    The units say 110-240 volt, 50-60hz. Yes two 24volt units can run parallel for 24v@94amp.
                    The 24v i sent to the UK cost $60 to ship.
                    • Anbjorn
                      • Apr 2009
                      • 255
                      Great,
                      Do you mind checking the shipping cost to Norway? Zip code 6065
                      What is the physical size and weight of two 24V units?
                      Anbjørn
                      • Chrisg81983
                        • Jul 2011
                        • 1585
                        I see only what you ran with a double unit I am curios what you have ran with a single unit just in case i want to split it up
                        • JRPLANE
                          • Nov 2011
                          • 117
                          Anbjorn, looks like $74 extra to ship two 24v they weigh 9 lbs each
                          Chris, i have a friend run to cell pro 10's at the same time, he charges 4-5000/3s at a time. You have 47 amps to work with.
                          • JRPLANE
                            • Nov 2011
                            • 117
                            Anbjorn, rechecking I can ship for aditional $55 not$74
                            • Clueless1
                              • May 2011
                              • 301
                              Jrplane,
                              Money sent!
                              Thanks,
                              Todd
