Cad/cam and Machining Services
  • riptide1
    • Feb 2011
    • 305
    Joe, I have a big prop balancer that has adjustable cones for different sized prop shafts. These cones with thumb screws make it impossible for me to balance the floating shaft, before putting a prop on it. I would have to balance each part individually due to the design of taking it apart and putting it back in a different position each time you work the prop. I only use 3/16" props, so it would be great to have just a 3/16" shaft perfectly balanced with machined end points.002.jpg013.jpg015.jpg016.jpg
    • riptide1
      • Feb 2011
      • 305
      Guys please don't say get a TFL balancer, because I have one and the finish on the magnets has come off in less than 6 months. 010.jpg012.jpg
        Shafts are the main difficulty. Kintec has been trying to get a machine shop to do the precision grinding required for these kinds of shafts.
        I'm not shure if you could do it by machining, it may not be true. Precision circular grinding is a bit of an art. I have been thinking to attempt this but, I don't have the right machines.
        Originally posted by riptide1 View Post
        Joe, I have a big prop balancer that has adjustable cones for different sized prop shafts. These cones with thumb screws make it impossible for me to balance the floating shaft, before putting a prop on it. I would have to balance each part individually due to the design of taking it apart and putting it back in a different position each time you work the prop. I only use 3/16" props, so it would be great to have just a 3/16" shaft perfectly balanced with machined end points.[ATTACH=CONFIG]76640[/ATTACH][ATTACH=CONFIG]76641[/ATTACH][ATTACH=CONFIG]76642[/ATTACH][ATTACH=CONFIG]76643[/ATTACH]
        • riptide1
          • Feb 2011
          • 305
          Ray, I'm glad to hear others have discovered this need. My props would be a little better if I could get more precision from the balancer tool.
          • Chrisg81983
            • Jul 2011
            • 1585
            @ riptide what make is this balancer and where did u get it thanks Chris g
            • riptide1
              • Feb 2011
              • 305
              Chris, here's the link ...http://www.whhonline.com/product-p/acc25.htm I really like the big high power neodymium magnets with a nice finish ...now if only I could find someone to knock out a 3/16" shaft for it.
              • Basstronics
                • 2384
                All you need is any surface grinder and a whirly gig.
                Put the shaft in a collet, put it on the magnet at some angle, use side of grinding wheel. Set the part by side of wheel. Raise wheel, push part out a bit. Start grinder and bring the wheel down slowly. You will probably get a nice size radius on the wheel if you are doing alot. Just a few shouldnt hurt.
                  I thought of this too or using my lathe and a dremel. I don't know the dremel runout tolerances though..
                  • Basstronics
                    • 2384
                    How would you attach the dremel?
                    Runout, probably not very good.
                    Any metal lather with a carbide bit will push/distort the material close to the point. Hi speed steel is WAAAAYYYY sharper, but to get a good point you gotta be dead center. Which as you know never happens.
                    Do you have an OD grinding attachment for your lathe?
                    I guess the technical name for the "whirly gig" is a punch former. Every shop Ive worked in has had one.
                    4:45 mark or so
                      I would have made a "whirly gig" to try it on my lathe but, I have some nice shafts.
                      You can get new good quality magnets to replace what has gone bad from China.
                      ...and for $12 you can get a fairly decent shaft (w/whole balancer) but, the shaft is 3mm from China.
                      • Meniscus
                        Refuse the box exists!
                        • 3312
                        I guess what I'm confused about is, why not just use a tiger paw on the grinder? I would think that you could start with any shaft that is true and work from there. As long as the shaft is spinning, I don't see the issue. I'm probably missing something here in translation. After all, how many of us truly profile the blades, not to mention the cupping or thickness? In my book, I think that would matter more. Plus most folks use bushings. That means you've got a certain level of deflection at speed anyway. That's one of the main reasons why I've gone to bearings in the strut. Yeah, it's considerably more expensive, but I've never had an issue with them, as long as you break them in first prior to running.
                        • J Solinger
                          • Apr 2008
                          • 197
                          What length do you need from point to point?
                          Joe Solinger
                          • riptide1
                            • Feb 2011
                            • 305
                            Joe,
                            90mm is what it has now. I know that drill blanks are sometimes sold in 3 1/2" lengths which is 88.9mm and would be close enough. I can ship the balancer and/or the rod.
                            • 120man
                              • 30
                              dual rudder setup
                              Hi Joe
                              Looks like you do incredible work.
                              I need help on a dual rudder setup. I need to attach a steering linkage to the water passages of 2 rudders, and keep the water flow from the pickups. Im thinking if you can make me a threaded tube to screw in, I can attach the link to that and put the coolant hose on last. Here is a rough pic of what Im going for...
                              I was hoping you could open up the hole and re-thread it to a larger size, but Im not sure there is enough room.
                              If you have a better Idea, or if I can clarify in any way let me know. If I can get a "round about" price that would be great
                              Thanks,
                              Jeremiah
                              • J Solinger
                                • Apr 2008
                                • 197
                                Hi Jeremiah. What size thread is in there now? Maybe we can come up with something quick and easy.
                                Joe Solinger
