Tunnel Hull Set-Up Board
  • JRS Innovations
    • Oct 2010
    • 169
    Hello All
    I have designed a Set-Up board for FE / 3.5 Tunnel Hulls.
    It is 11 1/2" wide x 34" long x 3 1/2" high off table.
    I have made the CoG bar adjustable from 3" to 9" from the Transom.
    I have engraved a line across to measure and set the CoG Bar and to line up the transom to.
    I have engraved 2 short lines to line up the inside of the tunnel areas of the hull.
    Included are (2) 12mm, (3) 6mm & (3) 3mm shims to place under the lower units cavitation plate
    to be able to set the lower unit perfectly flat and 90 degrees to the hull & also adjust the correct height
    of the lower unit in relation to the bottom of the sponsons.
    It really makes set-up a lot better and more accurate.
    Items shown in pictures 06 & 07 are not included.
    $105.00 plus S&H
