Decal Graphics - NO COST
  • monojeff
    • Nov 2010
    • 2728
    #106
    Originally posted by dddmx3 View Post
    Yeah their good decals but I think the lightbulb on top needs more work. You kinda have to look at it until you get that it's a lightbulb! :p
    The lightbulb is exactly the same as the factory race boat.
    Everything is pretty much exactly to scale.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • dddmx3
      • Mar 2010
      • 244
      #107
      Well idk.. Maybe it is good I just didn't see it that well in
      The pics..
      After all is said and done, more is said than done.
      • monojeff
        • Nov 2010
        • 2728
        #108
        No worries.
        Here are some pics for everyone to check out.
        Full size Miss Longlite & Chuds Scale Mini Mystic Miss Longlite
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • dddmx3
          • Mar 2010
          • 244
          #109
          Nice nice...
          • sailr
            • 7128
            #110
            I have a question about your graphics. Can you print white? or does white have to happen by default by a clear area over a white surface?
            Mini Cat Racing USA
            www.minicatracingusa.com
            • monojeff
              • Nov 2010
              • 2728
              #111
              First let me ask what are you trying to accomplish with the white printing?
              Typically the only reason to print with a white would be if the decals were being printed on a clear surface. Like a window cling or clear vinyl.
              So with that said rarely is there a need to print white.
              White is the default color of vinyl we use to print decals & wraps & you can cut away (contour cut) any white background that you don't want so there is only the colors that were printed showing.
              The attached photo is a door skin on a mini truck that was printed & contour cut so it has no background.
              OSE GIFTING ELF
              HAPPY HOLIDAYS!!
              • sailr
                • 7128
                #112
                OK. I had no idea if you were printing on vinyl or what. That explains it! Thanks! I'm gonna need a graphic that goes on a black background that has white in it. I'm doing a 1/10th scale 1985 Coors Light U-100 hydro. Once I figure out the exact size I need it, I'll send you the artwork. Here's a jpg of it.
                Thanks!
                Mini Cat Racing USA
                • monojeff
                  • Nov 2010
                  • 2728
                  #113
                  Sounds good keep me posted.
                  I do both printed decal & wraps as well as regular cut letters & decals in any & all colors.
                  As well as Banners, Full size vehicle decals & wraps & more.
                  I'm about to start on a 1/10 scale U-1 Miss Budweiser Build in the next month or so.
                  Hope you start a build thread on yours.
                  OSE GIFTING ELF
                  HAPPY HOLIDAYS!!
                  • sailr
                    • 7128
                    #114
                    Cool! I drool over that equipment! I'm a graphic designer in my spare time. I brokered with a shop in Tampa that did all that until they went out of business. Just zeroed in on a new one a short distance from me that will do broker deals. It's a fun business but times are tough everywhere. Hope you are doing well! I will figure out the size for those Coors logos soon. What format do you prefer? I mostly use CorelDRAW. I can convert to any format you like.
                    What is the thinnest material you can print on so it doesn't take so many coats of clear to hide the edges? THANKS!!
                    Mini Cat Racing USA
                    • monojeff
                      • Nov 2010
                      • 2728
                      #115
                      The vinyl that is printed on is 2-3mil thick.
                      Typically it gets laminated but if your going to clear over it then this doesn't need to be done so it is as thin as possible for you.
                      EPS file is best or PDF just make sure it is in vector format.
                      If not then high resolution jpeg or pdf is fine & I can work with that as well.
                      I already have the coors logos if you need them let me know so you can size them the way you want.
                      OSE GIFTING ELF
                      HAPPY HOLIDAYS!!
                      • sailr
                        • 7128
                        #116
                        Thanks. I don't think I have the Coors Light logo in Vector. All I could find are bitmaps. Do you have the Coors Light logo like I posted here? If so, that's great. All I need to give you is the dimensions. I'll try to get to that later this week. I suspect the printing is a bit delicate if not laminated so care has to be taken until they are cleared?
                        Mini Cat Racing USA
                        • monojeff
                          • Nov 2010
                          • 2728
                          #117
                          Yes I have the same logo you posted.
                          All I would need are the dimensions.
                          Yes it is a lot easier to stretch it & or scratch it but it would typically be masked to protect this from happening until you got it on the desired surface.
                          PM me when your ready & we can discuss details.
                          OSE GIFTING ELF
                          HAPPY HOLIDAYS!!
                          • dano1
                            • Dec 2010
                            • 439
                            #118
                            I have a red hull hydro thats a miss vegas aquacraft 1/12 scale, would like miss snap on on the sponsons and two more smaller for the cowl and one across rear fin, pm me on prices please.
                            Thanks
                            dano
                            • monojeff
                              • Nov 2010
                              • 2728
                              #119
                              Thanks
                              dano
                              PM sent
                              OSE GIFTING ELF
                              HAPPY HOLIDAYS!!
                              • sailr
                                • 7128
                                #120
                                sounds good!
                                Mini Cat Racing USA
