anyone heard of Vac-U-Pickle
    Originally posted by okieman98 View Post
    i just looked it does have the 1500 kv motor, and a 3s 45 amp esc
    also have the the motley crew on 4s to
    My Bad, i thought it came with the FasTech 45amp ESC which was rated for 4s. And Travis is right, space is limited.
    I use the AquaCraft ESC, it barely fits across because the current version of the ESC has a longer cap.
    • okieman98
      • Jan 2014
      • 229
      ok then the rx and tx should work then i guessing
      1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' mono
        yes Sir, the MR200 rx is a great unit, while the tx doesn't have model memory, it is still a good radio.
          I ordered a seaking 60 amp esc which is smaller in size for mine. It was like 44 bux.
          • okieman98
            • Jan 2014
            • 229
            ok thanks everyone, all this info helps alot. cant wait to order it and get started
              Travis, which version? V2 or V3?
              • revoltrunner
                • May 2014
                • 646
                Here's mine. it's lots of fun and fast
                  LOl...
                  Now this completes the package... Properchopper had long ago posted something like this.
                    The V3. It's very nice looking (like it's big brother) and compact. Came in today....only 2s and 3s tho
                      Good to know!
                      • okieman98
                        • Jan 2014
                        • 229
                        y can only ron 3 s on that esc 60 amp?
                          Yes.
                          http://www.offshoreelectrics.com/pro...seaking-60a-v3
                          • okieman98
                            • Jan 2014
                            • 229
                            ok got lost somewhere with the research i have been doing, lol, i was thinking i saw these run on 4 s. going to order after the 1st of the month so drifting around finding where to get parts and so on.
                              You should get an ESC that is 4s compatible. I think the 90A would be a good choice.
                              Sent from my Droid using Tapatalk 2
                              • Doug Smock
                                • 5359
                                You did. I still run one on 2x2s 5000 45c wired in series with a AQ 2030 and 60a control. It runs great with a M cut X442.
                                http://www.offshoreelectrics.com/pro...=dh-aqcom-2030
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
