New Seakinmg 120 ESC
  • MORIDE
    • 108
    I just ordered a new Seaking 120 amp esc, It is replacing an old Seaking V1 or 2 120 amp esc. My question is on the old esc I ran a separate battery pack and did not use the bec, I run 5S should I do the same on the V3 esc or is it safe to use the BEC?
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    I used the bec on the v1 esc on 5s. Not sure why you ran a pack to begin with. Bec is fine to use
    • MORIDE
      • 108
      there are lots of old post regarding bypassing the ESC BEC if using any more than 4S on the older ESC's.
        Make Total Destroy
        • Mar 2014
        • 1952
        i dunno man, I've seen those same posts... i always used the built in bec without ANY issues
          With the new HW esc's the BEC is a UBEC in the 120 and 180 versions and are pretty good to use but, the 60 amp and 30 amp are Linear BEC that I would not use.
          To each his own, sometimes I run a RX pack and sometimes I don't. Spec boats no, modded boats yes.
          • 785boats
            Wet Track Racing
            • 3423
            I've always used the BEC even on 6s. That's what they're there for.
            Those old posts mainly referred to ESC's with linear regulators . Most ESC's these days use the Switching Mode regulators which can switch higher voltages with much smaller losses.
            Ray.
            Just as a matter of interest. Where did you see that their smaller ESC's still used the linear mode regulators? I assumed that they used switch mode too. Although I've never used one of those ESC's.
            Cheers.
            Paul.
              It's right in the specs http://www.offshoreelectrics.com/pro...30a-v3&cat=123
              Specification
              Continuous Current: 30A
              Peak Current: 180A
              Input: 2-3S Lipo
              BEC Type: Linear Mode
              BEC Output: 6V/1A
              Should be fine though; I've got a 30amp unit to repair a boat that did not need it so, I'll use it for when I ever put my HK podracer together...
              • Spartanator
                • 1060
                I think that if you use a external BEC it will provide cooler temps... I think... My SK180V3 runs ok with an external BEC. Up to you. If it was up to me then I would put a cap pack and BEC on it to be extra safe. Also depends what your using it in.
