Joysway UH-1 Catamaran Model number 9112H
  • fidelity101
    • Aug 2014
    • 357
    I'm new to electric boats, I've had a gas Warehouse Hobbies Team Enforcer Pro for a few years and thought I'd try my hand at electrics. I purchased the Joysway UH-1 (http://www.ebay.com/itm/231292164109) and it looks like a beautiful boat.
    The good:
    - Motor and ESC seem to stay very cool on 8S.
    - Boat runs well on 6S wit decent speeds...I was using a 6S 5000mah pack
    - Looks!...This boat just looks cool!
    The bad:
    - Hull quality. The boat fell apart when attempting to run the boat on 8S using two 4S 4000mah 25C battery packs. The boat failed BIG TIME as the seem gave way and the boat seemed to crumble. Here are some before and after pictures.
    - Battery tray and CG. The battery tray will accept two 4S 5000mah packs but not much more. That should be enough for 4 minute run times. The hull comes out of the water quickly as the batteries are placed between the sponsons. I think this boat would benefit from two 8S 5000mah packs with one pack being placed over each sponson for some nose weight and improved run times.
    Verdict:
    - I would definitely buy another one if I could find a good price, but I would spend a few days adding carbon fiber cloth and epoxy on the inside and around the entire joint section where the top and bottom hull sections meet. The overall hull is approximately 1/16" thin and it appears that quick setting resin was the only thing used to hold the hull pieces together.
    Here are the pictures I managed to take before and after the hull failure. I am still waiting to hear back from the ebay seller as to a replacement hull...they do not appear to be overly willing to help get me back in the water anytime soon.IMG_2017.jpgIMG_2016.jpgIMG_2020.jpgIMG_2023.jpg
    • 7277
    so it just came apart while running, no crash etc? Not good if so!
    • fidelity101
      • Aug 2014
      • 357
      Here is a picture of the damage after my first run on 8S.
      Also, to those of you who mentioned that upgrading the ESC would be a high priority, I was unable to verify it...sorry. The ESC was cold to the touch after a 4 minutes run with the 6S 5000mah 50C pack. After running it on 8S, the water flooding inside the boat did a lot of cooling for me...so it was hard to see if it got warm. :-(
      I know that some Chinese products are better than others, but I'm really bummed about this entire experience. I really wanted to get into RC boating this weekend and my entire family (kids and parents) were impressed with the way the boat looked. They also laughed very hard when the boat failed and started to sink. They laughed even harder when I dove in, fully clothed, to prevent it from sinking any further. I was able to recover the hull and the canopy...so hopefully the electronics will work again (I'm giving them a few days to dry out)
      I think I may have to buy another boat and return this one because the ebay seller is being very unfriendly and extremely unhelpful. I asked for a replacement model and they said "hahaha"
        • 7277
        Was there any flotation in the hull?
        • fidelity101
          • Aug 2014
          • 357
          It comes with an empty hull...I recalled from my gas days that using foam is a great way to provide cheap security so I used the tubes you can see in picture 4. I hot glued them inside the hull. That prevented the boat from going underwater completely...4" of the hull stayed above the water as it was vertical in the water so the battery tray was slowly starting to get wet. I dove in and "hopefully" disconnected the battery before any damage occurred.
          The boat seller told me they've never had a single report of failure and said it was the way I drove it. Not sure why it fell apart at half throttle other than the extremely thin hull.
          I am two days into my vacation and I've spent a few hours on the phone with eBay and asking the seller for help...I think boating it not in the cards anymore...really stinks
          • fusion_m8
            • Jan 2013
            • 53
            Time to cut your losses and frustrations bro, not any hull can handle the physical stresses that 8s can dish out. Trying to repair a broken hull like the one you got is akin to glueing back a broken mirror, its never going to be the same. Salvage the electrics and get a good hull from the OSE shop, there are many on offer like the one below that can handle 8S and they are reasonable priced with customer service you know you can trust.
            http://www.offshoreelectrics.com/pro...prod=aero-1127
            If you are willing to settle for 6S, there is a more affordable hull on offer that has been proven to be a great performer:
            http://www.offshoreelectrics.com/pro...prod=Aero-MM-2
            • fidelity101
              • Aug 2014
              • 357
              I agree with you fusion. However, the hull isn't a complete failure...I should be able to fix it in a few evenings and add a significant amount of carbon fiber and fiberglass support to the entire hull. It will add weight, but it will be worth it in the long run. I'm also going to cut out the stock battery tray and make two more trays to the left and right of the stock tray location so I can run 8S 6000mah packs on each side for a total of 8S 12Ah power...which should give me a solid 12 minute run time. :-) What do you guys think about trim tabs on a catamaran? This boat will live to see another day and I'd rather spend time fixing it up than doing more search on finding a suitable replacement for the electronics I'd be pulling out of it. :-)
              But then again, if this boat hobby is anything like the RC airplane hobby, I'll probably have 5-10 boats in my shop before the end of the year. :)
              • fusion_m8
                • Jan 2013
                • 53
                That sounds like a good plan if you are able to repair the hull, as for myself I lack the tools and the expertise to perform such a repair if it were to happen to me. But seriously...8S??? That's a heck of a lot of power for any RTR hull to handle...
                • fidelity101
                  • Aug 2014
                  • 357
                  I think the total power (watts) divided by the total weight of the boat is a better indicator of performance. My friend has the Genesis and on 4S, it's crazy fast! I ran the Joysway on 6S 5000mah packs because I wanted to see how it ran and it did ok, I'm guessing it was in the 60-70A range, pushing approximately 1300 watts and it went about 20-25mph. On 8S, I was only able to test with 2x4S 4000mah 25c packs but it was much MUCH faster. The amp draw was probably closer to 100A at WOT and I was never able to see max speed because the hull failed during the test. The hull on the joysway is so thin that once the gelcoat broke out of the way and exposed the fiberglass, I could clearly see holes in the fiberglass. There wasn't even enough resin in there to seal the fiberglass and the fiberglass was only a single layer. There is no way it can handle much more than 25-30mph in stock form because there just isn't enough support.
                  I really wanted to get a replacement but the seller was very much against it...so I'm going to look for other options. If anyone is thinking about getting a joysway hull, the price is definitely right if you have the time and knowledge required to fix it up properly. If I do end up with another cheap Chinese manufactured hull, I'll take some detailed pictures during the build process before the first maiden. :) To me, that seems like an easier option than buying a quality hull and installing the flex shaft, engine and ESC because I've never done that before and I'm much more confident in my ability to reinforce fiberglass than to try and correctly install running gear.
                  • fidelity101
                    • Aug 2014
                    • 357
                    I just found out that atomikrc.com has these listed as "OUT OF STOCK" because 50% of all the boats had a split hull on arrival! The manufacturer never put a single layer of fiberglass over the seam and most of the boats were split when received by Atomik, apparently the United States distribution for Venom and Joysway. I wish I had known that information before buying this boat! I wish the person going by the ebay username "UJTOYS" would verify this information himself and stop selling the product until it gets fixed!
                    Does anyone know how to contact the Venom guys on this forum? I'd like them to verify this information. I'd also like to find a way to verify this information with ebay to force their user "UJTOYS" into honoring some sort of warranty or replacement.
                    • fidelity101
                      • Aug 2014
                      • 357
                      In case anyone is interested, here are the pictures of the inside of the UH-1. I think you could increase the thickness of the hull and make it work but this is one THIN hull.
                      • fidelity101
                        • Aug 2014
                        • 357
                        New boat, before and after photos. I'm determined to make this thing run properly. New running hardware provided by Chris Fine. Replaced the prop, shaft, collet, ... Entire system. Stock prop was 60mm and new prop is 452 Octura...apparently 60mm is a bit big for an 8S setup on a 1050kv motor.
                        Before overhaul:
                        ImageUploadedByTapatalk1409494649.873867.jpgImageUploadedByTapatalk1409494669.822209.jpgImageUploadedByTapatalk1409494686.174544.jpgImageUploadedByTapatalk1409494707.858073.jpgImageUploadedByTapatalk1409494720.959324.jpg
                        • fidelity101
                          • Aug 2014
                          • 357
                          ImageUploadedByTapatalk1409494760.763120.jpgImageUploadedByTapatalk1409494774.597778.jpg
                          This stuff is pretty low quality! Wooden supports didn't even bond to this junk so the engine was very loose in the hull
                          • fidelity101
                            • Aug 2014
                            • 357
                            Upgrade pictures:
                            ImageUploadedByTapatalk1409494839.902877.jpgImageUploadedByTapatalk1409494858.156232.jpgImageUploadedByTapatalk1409494879.957619.jpgImageUploadedByTapatalk1409494898.624481.jpgImageUploadedByTapatalk1409494911.825892.jpg
                            More to come
                            • fidelity101
                              • Aug 2014
                              • 357
                              2 pound polyurethane foam in the hull and sponsons and sealed all air holes with west systems marine epoxy and filler.
                              ImageUploadedByTapatalk1409495004.934992.jpgImageUploadedByTapatalk1409495015.051106.jpgImageUploadedByTapatalk1409495049.520614.jpg
                              Next step is to cut the new shaft and attach to hull. I'm going to remove that pressure fitted ball bearing inside the hull and replace it with the aeromarine system that includes the oil injection piece...it looks cool! Also purchased an aluminum engine mount, leopard motor and swordfish 200A 8s capable esc...I really hope the esc will hold up. Purchased a new battery tray from aeromarine do the life battery and servo will be sealed in the event of a flip.
                              Also going to add foam to the inside of the hatch...it sinks fast without foam...I know from experience.
