    • 5660
    #211
    On both of mine, I use the existing outer mounting hole for the lower hole of the UL-1 bracket, and then drill a top hole...bend slightly once the fin is on.
    Thanks, I just thought I might break something if I bend the bracket while it is already on the hull, guess the hull with the doubler is stronger than I thought!
      • 7277
      #212
      I went further and added an aluminum plate on top of the plywood doubler.
      • Monica Smith
        • May 2013
        • 162
        #213
        Sorry, anybody can answer me, is there any problem with OSE private message? Today I tried to answer some private messages here, but couldn't send out!
        When we are no longer able to change a situation, we are challenged to change ourselves.
        Email: monicagong76@qq.com
        • flraptor07
          • Aug 2013
          • 2451
          #214
          Monica; Not that I know of, I worked for me last night
          • LiPo Power
            DJI Drone Advanced Pilot
            • 3186
            #215
            Monica, sometimes when receiving person has its inbox full you will not be able to sent it....
            Robert
            Canada
            • Monica Smith
              • May 2013
              • 162
              #216
              No! Just now I tried my private email again, I can receive messages, but I CAN'T SEND ANY MESSAGES OUT FROM MY ACCOUNT Yet! I don't know what was wrong with my private account.
              Here is my apologies for all the people who sent me private inquiry, I can't reply in time. If need, please send to my email address directly: kwl@tflhobby.com
              PS: Thank you, LiPo Power, I did get your message, but couldn't send out the reply.
                • 5660
                #217
                Doby, please let me know if I should post these pictures and comments in a separate thread, I don't want to clutter up your thread, thanks!
                I had to notch the rear motor support ring in order for it to seat correctly without unnecessarily enlarging holes on the side motor rails to find a spot for good/proper ring support. This worked and the collet to cable alignment is perfect! Very pleased, TFL did a good job with the angle of the tube.DSCN4574_4905.jpg
                Well, I tried to avoid bending the bracket on the hull, and using pliers didn't work. Not having the proper tools like a table vise is not a good thing! I shimmed it with a FG prototype board. All is good, inside I used G-10 FG for a second doubler. DSCN4602_4972.jpg DSCN4606_4975.jpg DSCN4603_4973.jpg DSCN4609_4978.jpg
                Doby, excuse me for cluttering up your thread, question is where you put the JB Weld for the stuffing tube, how much sending /roughing up was it necessary for the JB Weld to "grab" the bottom and the brass tube?
                • ron1950
                  • 3024
                  #218
                  well my stuffing tube almost fell out of the boat so no prob getting to it....I sanded the tube till it was shiney etc....taped around the hole as doby did in this thread somewhere just roughed up that area with sand paper and poured the jb,,,he has pics of it on here somewhere
                    • 5660
                    #219
                    Thanks Ron, my stuffing tube is pretty secured.
                    Did you solve your COG issue?
                    • ron1950
                      • 3024
                      #220
                      no never did fix the cg....I am traveling with the wife for her business so not home at all sence I ran it last month....I will prob try to drop the strut and fix the turn fin movement problem and give it a try and see how it does...if the bow comes down then I may leave it and play with the props it ran pretty well with the m545 but there is more speed there somewhere
                        • 7277
                        #221
                        Guys...no problem cluttering up the thread with good info and ideas..I'm just trying to keep the P-Spec and the P-Sport stuff in their respective threads..
                        As long as its in the right thread, clutter away
                        I used a #60 grit sandpaper (i think) on the tube as well as the hull...I prefer rougher surfaces to JB weld onto. If you look at the P-Spec thread...somewhere around the begining is a pic of the JB weld area I used.
                          • 7277
                          #222
                          Here it is:
                          http://forums.offshoreelectrics.com/...129#post520129
                          • flraptor07
                            • Aug 2013
                            • 2451
                            #223
                            I like that epoxy job somebody did where they CAed a oring down around the tube and poured the jb in the oring. That looked pretty slick, I think I'll try that on my next one.
                            • ron1950
                              • 3024
                              #224
                              yes the o ring is good but this boat has the servo tray in the way so u would have to remove it or use the JB on the bottom
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #225
                                Yeah I saw that, I got a Popeye coming for the second time thanx to USPS it's no wonder they're going under!
