Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Superhydrophobic and oleophobic coating - Rc Boaters Forum
  • egneg
    • 4664
    I would like to see how this would work on a boat hull.
    $60.00/quart bottom coat and $100.00/quart top coat but they cover 60 square feet.
    IMPBA 20481S D-12
  • Heaving Earth
    • 1877
    The video
    • Eodman
      • 1253
      Should break water adhesion on the hull .... making it slicker than goose grease! Wonder if it would make things waterproof.
      We did it with a Bang!
      Cats Are Where It's At!
      • Eodman
        • 1253
        wonder what kind of shelf life it has once its open!
        • egneg
          • 4664
          I was also wondering if it would be safe to use on electronics and shelf life once open. Maybe they will come out with smaller containers as $160.00 is a bit much. This is brand new stuff and they have been swamped with questions from folks.
          IMPBA 20481S D-12
          • Eodman
            • 1253
            Oh Steven, this could be aproduct for the store. Perhaps they would allow you to repackage it!
            • Heaving Earth
              • 1877
              It is non conductive and safe temps up to 300 degrees
              • egneg
                • 4664
                With Xylene being used as the solvent for this I am not sure about electronics - it may be just fine would have to try on an old esc or similar first.
                IMPBA 20481S D-12
                • demonioux
                  • Dec 2012
                  • 7
                  Just wondering if aplying a coat of this to the hull wont make it ultra repelent to the water causing to much lift therefore loosing control of our "small and lightweight" rc boats. Maybe if it is heavy enough 25lbs+ (not an ingeneer), the weight itself of the hull will be more than the repelent force at high speed, keeping the keel in the water. Great for saw but in small race boat just wondering if it will be more detrimenting than an aid tool.
                  • egneg
                    • 4664
                    IMPBA 20481S D-12
                    • egneg
                      • 4664
                      I don't think the displacement will be affected but if there is a significant speed increase you could be right.
                      IMPBA 20481S D-12
                      • LuckyDuc
                        Team Ducati Racing
                        • Dec 2008
                        • 989
                        As was mentioned on IW by a veteran boat racer, coating the bottom of your boat with a hydrophobic coating or wax may make your racing boat too slippery and reduce control/handling. SAW racing might be a different story, but with SAWs your boat is supposed to be setup to float on air at speed anyway.
                        I may ordered some of this stuff to try on my hunting boots though. There are two solvents required for cleanup. Xylene for part 1, and acetone for part 2.
                        • egneg
                          • 4664
                          If the boat was marginally under control in the first place it might but I don't see how a boat hull that is allowed to air out better and gain some speed will equate to loss of control.
                          IMPBA 20481S D-12
                          • demonioux
                            • Dec 2012
                            • 7
                            In theory it will be like driving an oil drop over water with minimal adhesion. Techinally it will be suspended on the water unable to break properly water tension (IN THEORY). therefore the hydrodynamic propertys of the hull design will be diminished... At least in theory, many other factors have to be taking into account.
                            • egneg
                              • 4664
                              Apples and Oranges - Strakes were designed to help air out a hull along with helping to keep it straight as do the sponsons on a cat or hydro. A drop of oil doesn't have these features so how can they be compared? I think we need to do some serious testing before any judgements can be made either way.
                              IMPBA 20481S D-12
