Outboard Cowl cover
  • Hp88
    • May 2012
    • 24
    Outboard Cowl cover
    Have been working on a twin brushless outboard cat project and needed some scale cowl covers to give this hull the right look. I came across a boat hull builder Evolution Rc , http://evorc.com.au/ they made me a cowl that would suit my 3.5 K&B outboard. This cowl started as a hand carved plug that was used to make the moulds. As you can see from the pics they did a great job to not only make the shape right but also to make it functional with the air vents.
    Moulds made from plug
    First test cowl out of the mould with air vents cut out
  • Hp88
    • May 2012
    • 24
    Having a test look at the one of the complet outboard on the hull, will have decals made for the outboards
    • tekne10
      • Oct 2011
      • 19
      They look absolutely amazing!!, How much did they cost you and would you be willing to sell a pair?
      • Hp88
        • May 2012
        • 24
        They will be available soon from http://evorc.com.au/ you can send them an email to find out more info.
        Cheers
        • dana
          • Mar 2010
          • 3660
          Pissah! I hope we're gonna get to see this thing go too?
          • tekne10
            • Oct 2011
            • 19
            Hey HP88, what paint did you use, to paint the outboard?
            • Hp88
              • May 2012
              • 24
              I used an etching primer for aluminium, then top coated with enamel black and a few coats of clear.
              • Jersey Crewmax
                • 495
                I'm assuming they would be to small for a K&B 7.5?
                • Hp88
                  • May 2012
                  • 24
                  It really depends on the size of the brushless motor mount for the 7.5 and how scale you want it to look. The 7.5 is about 40 mm longer then the 3.5 , so you will have more of the outboard leg protruding in front of the cowl.
                    • 9481
                    Awesome job man!
                    that could look killer on my PS295
                    • Hp88
                      • May 2012
                      • 24
                      Awesome job man!
                      Cheers mate, yeh the cowl just adds that finishing touch to an outboard powered hull.
                      • Hp88
                        • May 2012
                        • 24
                        Here is a pic of the decal set applied to the test cowl,
                        • Hp88
                          • May 2012
                          • 24
                          Here are some update pics of the decals applied to the outboard cowls,
                            • 9481
                            Looks amazing bro!
