new Turnigy 120amp 180 amp esc
  • bustitup
    • 3072
    Anyone seen this or is it just new to me?
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    The Turnigy ESCS are very good value but they are large. I do not water cool the ones I have as their size does not warrant it. I am talking about the HV and high amperage units. They may not fit in small boats and get enough air cooling. Also all of mine needed (3) required a Pistix to function, that may have changed today
    Douggie
    • bustitup
      • 3072
      Douggie
      What I meant was this looks like a new upgrade of the popular Turnigy 100amp hv
      that is so used in FE and it will run on 12s
      do you a run fan on yours Douggie?...how big a boat do you run them in
      • Flying Scotsman
        • 5195
        No to the fan. a 32" mono, a 34" cat and a 29" mono and all are HV ESCS
        Douggie
        • j.m.
          • 847
          • 6S HYDRO
            • 1325
            So douggie, your not cooling them at all. They dont get hot?
            • Flying Scotsman
              • 5195
              Nope, the heat sink is huge. This is for the 100amp HV esc. I can not speak for the new series.
              Douggie
              • Punisher 67
                Ignore list member #67
                • 1616
                I built a test stand to load test my motors and lipo's with a Seaking 180 , here is some video for what its worth
                • jcald2000
                  • 786
                  Nice Job as usual!
                  Camara need to be closer to screen, can't read data headers.
                  • Punisher 67
                    • 1616
                    Sorry about that I will re-do this video but need to buy a smaller prop for load , a 10/6 is to much for this motor and I don't want to smoke another high power high end unit
                    • jcald2000
                      • 786
                      I run an 8x4 on big motors and 7x3 on 4s motors.
                      • LiPo Power
                        DJI Drone Advanced Pilot
                        • 3678
                        This ESC looks good to me for the buck.... How would this compare to Castle ESC?
                        Canada
                        • bustitup
                          • 3072
                          I cant get my turnigy 180amp to give me full voltage.....I hope its my fault..hate to think I got a bad one
                          • Punisher 67
                            • 1616
                            Nick Can you post what your setup is and settings on the ESC , I find if I have the 3.4 volt cutoff even fully charged batteries hit the limiter very quickly and will not give full power on the test stand , maybe 30 seconds and thats it , 3.2v is what I set the cutoff at under load
                            I am sure it can easily hold its own against one , at least you don't void your warranty if you run 6S
                            • bustitup
                              • 3072
                              Peter
                              Its my mean machine cat
                              I used the optional programer set at
                              Forward only
                              Low start
                              LVC at 3.2 per cell
                              Low timing
                              Flight power 2s 5000mah 25c x2 in series
                              2200kv castle neu motor
                              Boat would only go 23mph......soon as I switched out the esc she ran 43mph
                              Using a m445 prop
