ESC waterproofing gel??
  • Sykojsy
    • 40
    Hi Guys,
    I've been hunting around and can't find what this is called, or even where i can get some! Any help would be good!
    The gel coating is starting to come off my Etti ESC and i don't want to get a new one just cause of that, if i can repair it with some gel, great. Was also thinking of maybe using it on the circuit board of a receiver?
    All help much appreciated!
    Jez
  • lonewolf
    • Jul 2007
    • 658
    The most common is dp 270 which is avail here under water proofing and hatchtape...
    • Sykojsy
      • 40
      Thanks Lonewolf, do you know if this goes solid or stays as a gel? Like what is originally used on the Etti ESC's.
      • lonewolf
        • Jul 2007
        • 658
        it gets hard. I am not sure of what is used on etti esc's but I do know that the dp270 works well...
        • ED66677
          • 1300
          silicon sealant?
          Emmanuel
          • Steven Vaccaro
            Administrator
            • 8724
            Its a gel? I would be cautious on using the dp270 on that esc. You are going to have to somehow remove all the gel first.
            Steven Vaccaro
            • lonewolf
              • Jul 2007
              • 658
              Good point Steven Corrosion x might be a better method???? Unless you can remove all the old coating...
              • Sykojsy
                • 40
                Thought about the silicon sealant, but been told it won't stick well once the esc warms up a bit.
                Yeah, the Etti has a gel coating under the heat shrink but that came off after it was used a few times (heat shrink that is). Corrosion X is just an inhibitant....not a sealant so i'll guess i'll have to remove the old gel and try with the Dp270.....try it on a cheap ESC first!!!
                • ED66677
                  • 1300
                  sorry to say that but this is not thrue! all my ESC's are moded with silicone sealant! and mines are "coated" so that the silicon make a kind of shell all around the ESC and also glue and holds the cooling plate in place!
                  basic silicon sealant will resist at least to 200°C (400°F)
                  heat transfert compound, for better heat transfert from MOSFet's to heat sink!
                  if you have access to, conformal coating material are better, few of them are acrylic, lot of them are silicon based and most of them are polyurethane.
                  Emmanuel
                  • Sykojsy
                    • 40
                    Ok, maybe thats the cheaper way to go then!!! I'll have a go with silicon sealant, thanks. The guy that told me works with sealants too......oh well!
                    Think you misunderstood the 2nd bit you quoted....i meant under the heat shrink (the shrinking plastic that goes around the batteries too, easiest way to explain it!!) the circuit board is covered in gel. The heat sink, is still well stuck to the circuit board!
                    • ED66677
                      • 1300
                      YEAH! you know I'm french and sometime understand after reading and reading again!!! They may have injected the silicon in the shrink tube while in place on the ESC??? This kind of encapsulation was commonly used before conformal coating material were designed!
                      Emmanuel
                      • Sykojsy
                        • 40
                        I'm the same Ed.....as a matter of fact...we are actually quite close....as I'm from Jersey! But saying that....do they do that heat transfer compound on here? Could do with some....
                        • ED66677
                          • 1300
                          you can get some heat sink compound from RS components p/n is 554-311, 20ml tube for £3.23 and that's the one I'm using!
                          Emmanuel
                          • NorthernBoater
                            • 811
                            Keep an eye on this product. It would be awesome if we could get our ESCs coated with this stuff.
                            • ED66677
                              • 1300
                              This product must cost a fortune, coating inside and outside of electronic devices whaou!
                              But I beleive the application process cannot be done without specific equipements, not at home!
                              We don't really need this stuff for our ESC, just a spray of Humiseal 1A33 and the job is done! I have a 1liter thin at home, it's the best, used in automotive, military certified... bad thing : contains VOCs!
                              Emmanuel
