JetChopper30 mono deep v hull FRP GLOW OR ELECTRIC
  • macace123
    Robotics Operator
    • Mar 2013
    • 477
    #46
    looking to get one in red let me know if i can get one soon
    Its not the boat its the driver http://namba2016fenats.com/
    Whiplash,Sprint Cat, Pursuit, 83' Miss Rock modern hydro JAE21, Dragon M11 Tunnel, Mickey Beez Jet, CF JAE21
    • leo_home
      • Jul 2007
      • 64
      #47
      Refer to Glenn Cupit's article on rudder set up, RUDDER "CASTER", A LITTLE CAR TALK, BACK TO BOATS. Articles talk about rudder length and rudder lift. With many testing, I got the following conclusion on JetChopper30 set up:
      Offset the rudder 55mm to the right. Pretty stable turn at full throttle. Rudder too close to the centre line has too much prop., keel lift, lower turn stability. In perfect situation, rudder lift just balance the prop., keel lift.
      Happy rc boating,
      Leo
      • leo_home
        • Jul 2007
        • 64
        #48
        I am relocating. Can make one for you on early September.
        Rgds,
        Leo
        • czegard
          • Nov 2012
          • 153
          #49
          Rgds,
          Leo
          Hello Leo,
          Just sent you a message.
          Please, check your inbox.
            • 7512
            #50
            want a red one?
            • czegard
              • Nov 2012
              • 153
              #51
              want a red one?
              No, thank you.
              I just have a question Regarding the rudder lengh for this hull.... Thinking for a heat Racing.
              • rayzerdesigns
                • Dec 2013
                • 1228
                #52
                are these still available
                  • 7512
                  #53
                  want a red one?
                  • properchopper
                    rcgoatbuild@snotmail.com
                    • 7708
                    #54
                    I'll check. But do give Doby a shout........
                    • leo_home
                      • Jul 2007
                      • 64
                      #55
                      Hello all,
                      It is available.
                      I used to have some rudder setup very similar to Tony's. I found that too much rudder lift. Than started a very time consuming testing: RUDDER LIFT: offset distance, distance from transom, blade length/area. Last for more than half a year. Nearly finish. Will soon publish a general text, pretty good rudder setup, aimed for oval racing.
                      Best regards,
                      Leo
                      • Heath M
                        • Mar 2008
                        • 865
                        #56
                        any updates on this hull?
                        Brisbane,QLD, Aussie
                        • Steven Vaccaro
                          Administrator
                          • 8934
                          #57
                          Hello all,
                          It is available.
                          Best regards,
                          Leo
                          Sounds interesting. Any more updates?
                          Steven Vaccaro
                          • wolffman
                            • Feb 2016
                            • 15
                            #58
                            Hi! I sent an email to leo. Just like more details about shiping !
                            but did not get an reply!
                            his email remains this? btorcboat@gmail.com
                            Thank you
                            • Steven Vaccaro
                              Administrator
                              • 8934
                              #59
                              send me an email and I can try to connect you with him.
                              http://www.offshoreelectrics.com/contact.php
                              Steven Vaccaro
                              • leo_home
                                • Jul 2007
                                • 64
                                #60
                                Recently rigged a JetChopper30 electric. Offset motor and offset drive shaft. The balancing weight is related to the speed. Would have some new video and figures posted here one some weeks later.
                                Leo
