Castles new Hydra Ice Now IN Stock
  • Steven Vaccaro
    Administrator
    • 8934
    I just spoke to Castle Creations, the Hydra Ice esc's are being built next week. They should be in stores in about 3 weeks.
    Steven Vaccaro
  • Chilli
    • 3204
    Cool. Thanks for the update!!
    Mike Chirillo
    www.capitolrcmodelboats.com
    • cacofonix
      • 243
      hello steven
      only 240A one, or other references ???
      herve
      • Joe Ford
        • Apr 2008
        • 101
        The case is already thermal epoxied directly to the MOSFETs...cooling tubes were all that was needed. There will be a Hydra ICE HV 200 for up to 12s lipo, and a Hydra ICE 240 for up to 8s. Both are single layer board designs...no more stacked boards! The 200 will obviously have no BEC, the 240 will have one good all the way up to 8s. Both controllers have datalogging to let you know the amps, volts, watts, motor rpm, ESC temperature, position you were on the throttle, percentage of full throttle, and ripple current. You can download, save, and chart this data on your computer after each run. Sample rates are 1, 2, 5, and 10Hz. And these will FINALLY have an AUTO LIPO SETTING! It will automatically detect the # of cells in your pack and set the cutoff for you. You'll also be able to choose the volts per cell cutoff you want (3v/cell, 3.1v/cell, etc). They should be on shelves by the end of the month!
        Joe Ford
        Product Specialist/Surface Team Manager
        Castle Creations
        • Darin Jordan
          • 9446
          Looks good to me! ICE, ICE, Baby!!
          Darin E. Jordan - Renton, WA
          • Chilli
            • 3204
            Got mine on pre-order. Cant wait to play with the data logging!
            Mike Chirillo
            • raptor347
              • Jul 2007
              • 1177
              The data logging is REALLY useful. It's amazing what you can learn about prop mods with a data logger.
              Brian "Snowman" Buaas
              Team Castle Creations
              NAMBA FE Chairman
                And it's amazing to see how high the amp draw is on some setups. I realize that the amp draw values displayed are not directly measured, but they are sure better than guessing.
                • Darin Jordan
                  • 9446
                  Hey guys... just curious... how long does this store the data? Does it clear it every run, or retain it. Also, how much data does it store? What does it do when it gets full?
                  • Joe Ford
                    • Apr 2008
                    • 101
                    It stores the data until the processor is full. The yellow LED flashes while it's storing data and goes to solid yellow when the processor is full. You would then need to clear the data out if you wanted more, or just leave it in there if you already have the info you need. It does not wipe out the data unless you tell it to. :)
                    Joe Ford
                    Castle Creations
                    • Darin Jordan
                      • 9446
                      Perfect... Thanks Joe!
                      Now, if we could just get a couple of external hookups... like an additional temp probe... and a GPS module...
                      • Insaniac
                        • 496
                        Where did you pre-order? I noticed it is late-Feb on Tower...
                        Support US hobby suppliers
                        • Chilli
                          • 3204
                          Flea Bay. They are showing Feb delivery also. They emailed me and said they had 20 on order and I can cancel any time if I got tired of waiting.
                          Mike Chirillo
                          • RCKong
                            • Sep 2009
                            • 1680
                            NICE... I'm really googling one or more of these babys. Hows the waterproofing ? Nice to see a CASTLE rep on here !
                            • Joe Ford
                              • Apr 2008
                              • 101
                              Sprayed with multiple layers of silicone conformal coating like all of our other marine controllers to make them highly water resistant, but not waterproof. A truly waterproof controller would be potted and even if a .02 part malfunctioned we would have to scrap the controller.
                              Joe Ford
                              Castle Creations
