New 40mm Water cooled motor mount
  • FE Wannabe
    • Jul 2007
    • 654
    Steven,
    I was wondering if you have any plans to carry the 40mm version of the water cooled motor mount?
    This mount should work nicely with Neu 15xx series, the Castle-Neu 15xx series, as well as the new Leopard 40mm motors that have recently hit the scene, as long as the motors are over 55mm long.
    (Correction, these mounts will not work with finned Neu or the finned Castle-Neu motors)
    PM me if you need the link.
    As always, I would dreather send you my money.
    Thanks,
    Brad
    Last edited by FE Wannabe; 06-02-2010, 12:26 PM. Reason: Correcting mis-information
    SoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150
  • m4a1usr
    Fast Electric Addict
    • 2036
    Nope. Doesnt work with the Castle/Neu or the finned series Neu motors. The clamping section will not open enough to get around the finned section. Already tried it. Dont waste your money unless you want to start cutting away some material from the motor or the clamp. It will work with the Xerun series motors.
    Should work for the longer Leopard 40mm series.
    John
    Change is the one Constant
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      John
      Explanation in photos:
      There isn't enough material in the top hole to line it up by drilling it either.
        • 9481
        nice find Brad!
        does someone have these now, I may order two of the Leopard motors soon
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          nice find Brad!
          http://cgi.ebay.com/aluminum-waterco...item439ed85023
          I have one in hand if you need it sooner. NIB.
            • 9481
            Sweet, thanks!
            hey that links looks like HOTR may be getting these motors to
            • FE Wannabe
              • Jul 2007
              • 654
              John
              John,
              Thanks for the correction, don't want to spread any bad info. I wasn't thinking about the fins not clearing the mount. I will correct my original post later.
              Does this mean the mount should work on the smooth can Neu 15xx series motors longer than 55mm as well? I was planning on using this mount with a Leopard 4074 2200kv anyway, so I should be fine.
              Thanks,
              Brad
              • FE Wannabe
                • Jul 2007
                • 654
                FighterCat57,
                If Brushless55 doesn't want the mount I may be interested in it.
                Let me know.
                Thanks,
                Brad
                • Steven Vaccaro
                  Administrator
                  • 8932
                  Originally posted by FE Wannabe View Post
                  Steven,
                  Thanks,
                  Brad
                  I have some on order. I should have them in 2-3 weeks along with some 40mm motors.
                  Steven Vaccaro
                    • 9481
                    Steven you da BOMB!
                    what versions are you going to get on the 40's
                    I would like two 2000kvs
                    • FE Wannabe
                      • Jul 2007
                      • 654
                      Steven,
                      I should've known you already had these in the works.
                      Thanks for the ETA.
                      Brad
                      • FighterCat57
                        "The" Fighter Cat
                        • Apr 2010
                        • 3784
                        Nice! It's a good little mount.
                        FYI- might be good to have extra stringers available separately, this mount can be used on the really long motors, like the 1527. The second set of stringers can be turned 120 degrees to hold the tail of the longer motors.
                        I was going to build a new stringer, but this is so solid that it bends the hull if I try to move it;
