What happened to 90 Degree 2.5mm Driver??
    • 9438
    I was fussing with motor mount screws and thought why not see if Steve has that cool tool for tight spots.
    I see it not available at this time. What is up Steve? They aren't rocket science to make...???
  • Steven Vaccaro
    Administrator
    • 8724
    The flex was unwinding. I tried to explain to people not to use it to break loose tight screws, to first loosen with a angled Allen, but it seemed to fall on deaf ears. I have two personal ones I use all the time for my boats and kids trucks with great success.
    Steven Vaccaro
    • Darin Jordan
      • 8332
      I wonder if it would work better if we used 1/16th wire instead...??? Hmmmm...
      That being said... I redid mine slightly, but use it all the time as well...
      Darin E. Jordan - Renton, WA
      • m4a1usr
        Fast Electric Addict
        • 2032
        I wonder if it would work better if we used 1/16th wire instead...?.
        A 4" piece of silicone tubing with the screw head slid inside works very well. Or if you really need some torque get a Chapman 90deg ratchet set. And you can get in some extremely tight spots with it. I like the flex tools OSE used to have too. I use it to get into the narrow hull areas where my big mitts dont fit!
        John
        Change is the one Constant
          • 9438
          Jeese... some peoples kids
          • egneg
            • 4664
            I tried to explain that it was to be used once things were loose as well. That and I tac welded the one I use.
            IMPBA 20481S D-12
            • Meniscus
              Refuse the box exists!
              • Jul 2008
              • 3222
              Originally posted by m4a1usr View Post
              ...Or if you really need some torque get a Chapman 90deg ratchet set. And you can get in some extremely tight spots with it....
              I agree. I have one that has served me very well for over 20 years. I don't think I've ever had an issue with it and there's tons of bits available.
              • sailr
                • Nov 2007
                • 6924
                I was Harbor Freight yesterday and ran across the tool in the photo. It's has a flexshaft for getting those pesky motor screws in/out.
                It includes a bunch of bits including 8 pcs of metric hex from 0.7 to 4.0!
                Cost $7.99
                Item No. 93916
                Mini Cat Racing USA
                www.minicatracingusa.com
                • Steven Vaccaro
                  Administrator
                  • 8724
                  I bought almost the same exact kit at Home Depot without the flex adapter. Bummer!
                  Steven Vaccaro
                  • Meniscus
                    • Jul 2008
                    • 3222
                    Sweet find Jim!
                    • sailr
                      • Nov 2007
                      • 6924
                      Can't wait to try it out. I hope the flex will take a small enough radius for it to be useful!
                      Mini Cat Racing USA
