Swordfish ESC's now instock
  • bustitup
    • 3072
    #46
    steve
    did you get my message about getting the swordfish software?
    • Steven Vaccaro
      Administrator
      • 8932
      #47
      Originally posted by bustitup View Post
      steve
      I sent it to you but it was rejected by your server.
      I will try to zip the file and send it again. Let me know if you dont get it in an hour.
      Steven Vaccaro
      • Ub Hauled
        • 3051
        #48
        powerup sequence and wiring video for the Swordfish 240hv.
        Steven, this video tutorial you made was great!
        You should have one done to each ESC you carry and to whatever needs a tutorial
        under your "tips" section.
        Great stuff...
        • Mieciu
          • Feb 2010
          • 21
          #49
          actually you do not have to wait until the end of those beeps - just hold throttle until it starts beeping :-)
          At the end you'll hear the number of cells detected
          http://www.offshoreelectrics.com/dow...40hvManual.pdf
          se page 3 for more details
          One important info: throttle range sometimes needs to be calibrated after changing ESC's settings.
          By the way - the fast startup mode is awesome especially for competition.
          Regards
          __________________________________________
          http://www.youtube.com/user/tygrysiek82
          • Steven Vaccaro
            Administrator
            • 8932
            #50
            Thanks for the info. I fixed your link so it points to the actual products instructions.
            Steven Vaccaro
            • Steven Vaccaro
              Administrator
              • 8932
              #51
              Software and manuals can now be found here.
              http://www.offshoreelectrics.com/downloads/hifei/
              Steven Vaccaro
              • bustitup
                • 3072
                #52
                ok got the software installed and when I have device manager open and see the uart bridge controller it says i'm on com6
                and the software only has com1 com2 com3 com4 ...there is no com6 in the software
                any fix?
                • Mieciu
                  • Feb 2010
                  • 21
                  #53
                  try com3 :-)
                  I had almost the same problem.... so I tested each port.
                  Procedure is simple: choose other ports and hit "open" button (and wait for green light)
                  In my case only com3 was ok (even if it's not shown in device manager)
                  hope it helps
                  Regards
                  Mieciu
                  • bustitup
                    • 3072
                    #54
                    Originally posted by Mieciu View Post
                    try com3 :-)
                    hope it helps
                    Regards
                    Mieciu
                    ok I tried that mie but it wouldnt work for me......BUT I found the fix...just right click on the uart bridge controller in device manager and choose properties then the port settings tab then advanced and it allows you to change the port com settings...I only had com2 the was available and it worked
                    • Steven Vaccaro
                      Administrator
                      • 8932
                      #55
                      Yes you can change the port on your pc, just make sure its not conflicting with something else trying to use the same port.
                      Steven Vaccaro
                      • ericspeed
                        • Mar 2010
                        • 67
                        #56
                        Hey steve, bustitups son-in-law here. If running 44+ volts should i set the voltage to 36volts when i program it or leave it on auto? And is there a way to program the esc to run only 90% or can it only be only be done with my controler .
                        • Steven Vaccaro
                          Administrator
                          • 8932
                          #57
                          Are you running a 12s lipo pack?
                          Steven Vaccaro
                          • bustitup
                            • 3072
                            #58
                            yes he is running two turnigy 6s packs on each motor and they are in series to each motor
                            • ericspeed
                              • Mar 2010
                              • 67
                              #59
                              esc not working
                              hey steve, its eric bustitups son-in-law. i bought two of the big swordfish. one i cant get to beep or make any noise. need to send it back. do i need an rma #? other one seems to be working fine. will also need to replace the screw in water fittings. i read where they said they were leaking and and broke some trying to tighten them. boy there fragile. let me know what i need to do?
                              • Steven Vaccaro
                                Administrator
                                • 8932
                                #60
                                For returns its best to email me. You can from the contacts page
                                http://www.offshoreelectrics.com/contact.php
                                Steven Vaccaro
