WTB: Decent Soldering Iron
  • Visual Perfection
    • May 2010
    • 312
    Looking for a soldring iron or torch that will be able to actually solder 5.5mm and 10 or 12ga wire. I have a cheapy walmart 40w iron but it just doesn't do it. I figured someone must have a used one laying around that they know works and is capable of what I am asking, so before I go to the store or online to get a new one I wanted to check here to try to save some money.
    Thanks.
    The Speeders *PB SW 26 BL *PB Formula FASTech
    The Cruiser *CBM Marlin Cruiser
    The Pool Toys *Proboat Mini-C (x2)
  • electric
    • 1744
    Hey, I bought mine at Hobby Lobby and it works great. Go to the section where they do stained glass and they have these soldering irons that are easily double that wattage with a screwdriver tip. I have had mine 3 years and solder the 5.5mm all the time with it and am still using the same tip.
    • bigwaveohs
      • 535
      Not sure why your 40 watt iron doesn't cut it. I used a 40 watt Weller to solder 10 ga wire and 8 mm bullets on a 200 A ESC with no problems at all...in fact it almost gets too hot for 5.5 mm bullets...they are about $19 at most hardware stores.
      I let the dogs out...
      • sailr
        • Nov 2007
        • 6924
        That's the Hobby Lobby crafts store, not the R/C place! www.hobbylobby.com
        Mini Cat Racing USA
        www.minicatracingusa.com
        • JimClark
          • 5902
          I have a 80 Watt Weller
          Billy Graham
            • 7990
            Not sure why your 40 watt iron doesn't cut it. I used a 40 watt Weller to solder 10 ga wire and 8 mm bullets on a 200 A ESC with no problems at all...in fact it almost gets too hot for 5.5 mm bullets....
            The secret is in the tip. I've used a 40W iron for years, I solder 8mm plugs to 8 gauge wire all the time. If you have a 1/4" chisel tip and keep it tinned, it will work well. Mine's not for sale.
              • 9438
              Steve sells the 80Watt Weller right on OSE! http://www.offshoreelectrics.com/pro...?prod=tv-sp80l
              • sailr
                • Nov 2007
                • 6924
                I checked the net and Steven's price on the 80watt weller is the best I found! Way to go Steven! Always giving us a good break!
                Mini Cat Racing USA
                • Visual Perfection
                  • May 2010
                  • 312
                  Thanks for the replies guys. I found one.
