just like the title says looking for a X640 or x440 sharpened and balanced
WTB X640 prop sharpened and balanced
Tags: None
Looked and found both. Which one you want? Also are you looking for 2 bladed or 3? I also have a couple "special" props in that size. As is cut down, cupped, detounged. Mucho magic but they are special purpose props and you need to know if the diameter is correct for you application. They tend to be SAW type props. Aggressive when they bite. But they would be more expensive. $25 shipped for a S/B/P 440 or 640.Change is the one Constant
I'll take the x640 for now I'm using it on the p1 king of shaves if that helps I would love a special prop as long as it fits my application
http://www.offshoreelectrics.com/pro...rod=octsb-x640. I'm pretty sure thus is the prop x640 sbp I also need a slip adapter the shaft size on the venom p1 is a 4mm
It's a 2 blade prop
Thanks John
Sounds good to me. A 2 bladed 640 it is. It turns out a small piece of K&S brass tubing is the perfect 4mm to .187 adapter. If you dont have any laying around I can cut you down a small piece for the adapter. Might need to take a file and deburr it. But it will work fine. PM me for paypal info. Thanks.
JohnChange is the one Constant
