WTB: 2mm Stainless Steel Wire for Drive
  • domp444
    • Jul 2009
    • 846
    I can't seem to find it anywhere. My LHS has piano wire only.
    I need this for my MHZ Mystic C5000 M, and I've never done anything with wire drives before so I'm clueless
  • HOTWATER
    • 2323
    contact Jeff Wohlt on here...he's the wire man!
    -Kent
    "Will race for cookies!"
    IMPBA D12
    • befu
      • Aug 2009
      • 980
      Did you try McMaster.com?
      They have three different pieces of 2mm stainless rounds 1 meter long.
      304 is product number 1272T11 and $3.18 each. Diameter tolerance is +0/-.025mm, but that shouldn't be too critical for a wire drive, would it?
      Brian
      • JimClark
        • 5902
        another one for McMastercarr.com
        Is it a straight shaft or does it actually need to bend?
        Billy Graham
        • RayR
          @SiestaKey.calm
          • Jun 2007
          • 1518
          You can get really good 2mm SS wire from the bicycle guys. Google 14 gauge ss bicycle spokes.
          Ray
          • domp444
            • Jul 2009
            • 846
            Thanks! The McMaster wire looks good. It will need to bend a little I believe.
            Also, what size Teflon liner and stuffing tube will I need?
            I appreciate the help :)
            • j.m.
              • Jul 2008
              • 838
              If you need it threaded on the end I can send you a few spokes.
              Jon
              • blackcat26
                High Speed Junkie
                • Sep 2009
                • 1598
                Dom, are you sure that 2mm wire will be ok on a 44" boat?
                • j.m.
                  • Jul 2008
                  • 838
                  Thats .078"....
                  http://www.offshoreelectrics.com/pro...rod=jw-wire078
                  • domp444
                    • Jul 2009
                    • 846
                    I don't think I need it threaded since I have the scale drives. The shafts are for 2mm wire, you just have to glue the wire in there with loctite.
                    I hope it'll be alright, that's what MHZ recommends. The scale drives I purchased for the mystic from MHZ have the 2mm drive shafts on them, so I'm guessing they'll work.
                    • j.m.
                      • Jul 2008
                      • 838
                      How long do you need?
                      Jon
                      • domp444
                        • Jul 2009
                        • 846
                        Hmm, not sure. I haven't started the build yet since it's my Christmas present didn't make any measurements yet. Probably like 10-12" though. And I'm only guessing.
                        • j.m.
                          • Jul 2008
                          • 838
                          I have a pile of 258mm spokes, so with the threads and j-bends cut off that would give you about 10" exactly.
                          • blackcat26
                            High Speed Junkie
                            • Sep 2009
                            • 1598
                            OK I was just wondering. I am not used to the bigger builds. If MHZ recommends it I'm sure it will be fine.
                            • domp444
                              • Jul 2009
                              • 846
                              Thanks j.m. :) I'll let you know if I decide to go with those, gotta do a bit more research first.
                              I sure hope MHZ is right, haha. Will the wire from McMaster allow a slight bend?
                              And can some please let me know the size of the Teflon and stuffing tubing I will need? :)
