wtb mini vee hull abs or fg
  • Alexgar
    • Aug 2009
    • 3701
    wanting to build a mini vee hull and need a hull, no hardware and no off the shelf proboat or aqua craft. new or used since im planning to repaint
    i have a bj 26 and a 15l i will trade also
  • Jesse J
    scale FE enthusiast
    • 7818
    I've got one that has half an inch of dust - I did retrofit the drive with a flex that goes into the steerable outdrive. I can post up pics if you like.
    "Look good doin' it"
    See the fleet
    • Alexgar
      • Aug 2009
      • 3701
      not an actual mini vee i have one and am looking for a more durable home for my electronics but for the right price i may recosider post pics please
      • Jesse J
        scale FE enthusiast
        • 7818
        What exactly are you looking for? a small vee hull? what dimensions are you after? I have a mini vee and mini rio... but not a small vee, sorry misunderstood.
        See the fleet
        • Alexgar
          • Aug 2009
          • 3701
          what kind of green we talking about?
          • Jesse J
            scale FE enthusiast
            • 7818
            pm sent. and that would be the good kind of green.
            See the fleet
            • Jesse J
              scale FE enthusiast
              • 7818
              I forgot how much I had done to this lil guy.
              retrofit straight shaft with .098" flex and 1/8" stub - I had to shim the drive
              Futaba S3114 servo, well seated and smooth
              turn fins/ trim tabs - with water pick up and transom fixture
              Hull and hatch are intact, no cracks or dings. the deck was a little sun faded when I got it, but still solid. I modified the inner tray some, but you may end up removing and glassing - not a bad move. I silicone sealed the hatch on - not a drop got in, just a strip of tape along the front of the hatch cause the little keeper broke off. Magnet in rear is still intact.
              all you see for $80 shipped. It is an x432 prop - I have a couple plastic ones I can throw in too. W/O prop, $60 shipped (and I still throw in assortment of plastic props)
              See the fleet
              • Alexgar
                • Aug 2009
                • 3701
                hows it run stable and is the motor mount standard clamp style?
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  Here is my last run with it - I was trying to flip it and no dice.
                  Motor mount? ... I can go look, but it would be the clamp style.
                  After seeing that vid... I am less in a hurry to sell. But if you really want it, I will still sell as described.
                  edit: looked for mount - nope. they are $2.99 at horizon hobby. You may be better off buying a bare hull ($38) and going from there. a brand new one is only $80. I can't let this one go for less than posted, too much time/upgrades involved.
                  See the fleet
                  • Alexgar
                    • Aug 2009
                    • 3701
                    im gonna pass looking for something more like a warzone 18"
                    sorry to waste your time thanks jesse
                    • Jesse J
                      scale FE enthusiast
                      • 7818
                      No problem. It was good to get that guy back out, I forgot how cool it is. You got me thinking of getting it back running again.
                      Also, you have clarified your needs.
                      good luck,
                      Jesse
                      See the fleet
                      • Alexgar
                        • Aug 2009
                        • 3701
                        im trying to use some mini hardware i have and it defetes the purpose to just buy another boat
                        • Jesse J
                          scale FE enthusiast
                          • 7818
                          make one out of foam and epoxy? a micro cat? I have the plans for a balsa cat you can scale to whatever size you want.
                          maybe you can talk Sailr Jim into just a Velocity hull?
                          See the fleet
                          • Alexgar
                            • Aug 2009
                            • 3701
                            i think its mono hardware
                            http://forums.offshoreelectrics.com/...ad.php?t=19214
                            • igottalongone
                              • 204
                              I have a sweet little mono for you, an MHZ Scorpion... 3 step, little monster... Brand new, never drilled, yellow...
                              Doesn't get any better than MHZ... $90 shipped...
                              Ron
