WTB Large Hull
  • JMSCARD
    • Mar 2010
    • 3444
    a df40 mono with a 1527 NEU is good for low 60's a 2215 to the 70's and a 2230 to the 80's.....
    • b.mcdaniel.2009
      • 1641
      Originally posted by JMSCARD View Post
      a df40 mono with a 1527 NEU is good for low to mid 60's a 2215 to the 70's and a 2230 to the 80's.....
      She'll handel those speeds? My main concern is bein able to run 40-50mph is 6"-12" shoppy water.
      ..Eagles may soar in the clouds, but weasels never get sucked into jet engines..56" P.I. Fountain /37"Genesis Cat.-1717/T-180/33" DF Copy-1717/T-180
      • JMSCARD
        • Mar 2010
        • 3444
        http://forums.offshoreelectrics.com/...ht=delta+force
        check out the vid and read the thread.... it may answer a few of your questions... :)
        heres the second vid with a samller prop and some cutting around.....
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Think about that by scale. How may speed boats do you see in 12 foot waves? 1/10 scale, do the math; 50" boat simulating a 50' boat, so a 12" wave would be a 12' wave.
          It get's pretty desolate here at the inlet when the waves get up to 6' or more and certainly aren't any regular boats doing 50mph in 6' chop.
          I've been working on a gasser for this very thing, but speeds in the 40ish range and room for lots of acceleration and part throttle running. On/off the throttle constantly to adjust to rapidly changing water conditions. I've boiled it down to the Express GTX or Aeromarine Apache. Again both in the 60 inch range and gas as there will be TONS of throttle manipulation and runtime's needed in the 20-30 minute range.
          • westbeach
            OSE Rocks!
            • 951
            I would stay away from the DF40 and get the DF Sniper 45 instead. Deeper vee, handle chop much better. To answer your question.
            HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
            • b.mcdaniel.2009
              • 1641
              Any vids of the DF 45".
              • JMSCARD
                • Mar 2010
                • 3444
                Heres anbjorn's:
                Heres KevinLews:
                Heres Peter Zichas:
                Each of these guys has +/- $3000 on the water
                • b.mcdaniel.2009
                  • 1641
                  Why would you say that?
                  • Rumdog
                    • 6453
                    Well, it is a fact. That's why he'd say that..
                    • westbeach
                      OSE Rocks!
                      • 951
                      What Nick had said too! Because I have a DF Cyberstorm, and it is a deeper vee than the DF33, as well as watching a few members here build and run the Sniper. as JM had posted links to.
                      • westbeach
                        OSE Rocks!
                        • 951
                        It's even stated here. http://www.offshoreelectrics.com/pro...prod=df-sniper, I know it is stated for the DF41 as well but it is not a true deep vee.
                        • b.mcdaniel.2009
                          • 1641
                          When will the df 45" be back in stock?
                          • tborisch
                            • 49
                            Originally posted by ScarabChris View Post
                            WOW!! Amazing boats. That turbine cat is wild. Whats in that boat like $15K?
                            Just north of $19k. There is a lot to it that you don't see.
                            Tom
                            • b.mcdaniel.2009
                              • 1641
                              Still looking!
                              • befu
                                • Aug 2009
                                • 980
                                40" and 52" mono's
                                http://forums.offshoreelectrics.com/...+kevlar+carbon
                                Look at last two post in this thread, is this anythng like what you are looking for?
                                The 40" is a mid vee. The 52" is a true 24 degree deep vee design with a sharp entry, eats rough water.
                                Brian
