Looking for a 32+ deep v or cat hull. I want to make it a gasser
WTB: 32+ hull
32" is small for a gasser.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
mono
I have a 40" mono with a zenoah in it now, surface drive hardware. I could take the motor and exhaust out of it or strip it down further. I will have to take some pictures and post them for you. It is a mid v. Not sure, maybe 20 degrees? White gelcoat, kevlar layup, strong boat.
also have a true deep vee, 24 degree deadrise, 52" long, kevlar layup. A couple actually, one has an old homelite in it. Another one was that kevlar/carbon blend, vacuum bagged in epoxy, carbon honeycomb for the the engine stringers. 52" long, foam flotation up front, stringers and built in radio box, about 5 lbs. That was going to be my fast boat, but got out of the nitro and gas. Want any .90 piccos?
will get pics tomorrow.
Brian
Kevlar, sweet!Originally posted by befu View PostI have a 40" mono with a zenoah in it now, surface drive hardware. I could take the motor and exhaust out of it or strip it down further. I will have to take some pictures and post them for you. It is a mid v. Not sure, maybe 20 degrees?
Brian
40" mono
Pretty straight forward. shallower V, set up for surface drive, 1/4" flex, 23cc zenoah modified by midwest zenoah, wrap to center tuned pipe, 1/4 scale rudder servo, remote charge jack on the radio box for the rc battery.
The rails on this one is 1/8" balsa core with carbon fiber on both sides. I forget what the specs were, but it is like the weight of 1/8" light ply and the strength of 1/4" aircraft ply or something. Very nice stuff, very strong, rather pricey. Hmmm, I might have an outrunner that would push this thing as a sport setup!
Couple of chips in the front that need to be patched, polyester gelcoat and kevlar layup. Setup more for heat racing.
Brian
52" deep vee
I have a few of these. From polyester gelcoat and kevlar that will hold a homelite, the carbon/kevlar one pictured here (no gelcoat - looks rough), to a couple not put together yet.
This one was setup for a .90 picco as the rails are 4" apart. Not sure you can fit a newer zenoah in it. it would be fast if you could. carbon fiber/nomex honeycomb core engine rails, all epoxy, vacuum bagged, strong! make you a deal with two picco .90s with fuel tanks and a Irwin quiet pipe.
Brian
? WHAT RULES?
