WTB 30A power supply
  • BHChieftain
    Fast Electric Addict
    • 2051
    Wanted: 12V, 30A+ power supply for a hyperion duo charger
    -Chief
  • JimClark
    • 5913
    Look here
    Billy Graham
      • 9481
      Oh wow, I could use one of those bad boys...
      • egneg
        • 4759
        You can make your own without to much difficulty. You can get a PSU from fleabay for under 25 bucks and a few dollars worth of stuff from Radio shack is all that is needed. I have one that I have ben using for quite some time now and I gave one to Diegoboy for Christmas. Here are a couple of links and a picture.
        IMPBA 20481S D-12
        • BHChieftain
          • 2051
          http://web2.murraystate.edu/andy.bat...owersupply.htm
          Thanks... but I can barely put together a boat, and I don't feel like messing around with that much power...
          I'm really only planning to charge at 1C, so a 20A supply should be more than enough-- anybody have something in this range they want to part with?
          -Chief
            • 9481
            Sweet!
            I have two of those lying around. how many amps can I see with this?
            • egneg
              • 4759
              Sweet!
              Depends on how many watts they are and it should be listed on the side for 12 volts.
              IMPBA 20481S D-12
                • 9481
                thanks, I'll take a look..
                • NativePaul
                  Greased Weasel
                  • 2770
                  If your making one from a computer PSU watch out for dual rail designs, very bad things can happen due to high eddy currents if you try to connect both rails of a dual rail PSU to supply the full rated ampage so either stick with single rail designs or make sure a dual rail design is rated for double what you need then only use 1 rail, (nice if you have 2 chargers as you can use 1 rail per charger and use both from 1 supply).
                  • JimClark
                    • 5913
                    here
                    Billy Graham
                    • NativePaul
                      Greased Weasel
                      • 2770
                      I have had 2 of the 20A versions of that supply and while I know many people that use them without problems my first blew at about 10A, charging 6s at 5A and the other started smoking charging a 4s at 5A.
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1743
                        how can you tell if it 2 rail or single rail?
                        • BHChieftain
                          • 2051
                          Thanks! I just lost an auction on this same power supply on ebay this morning. I'll check if this one is still available.
                          -Chief
                          • Boatman
                            • 875
                            I have a power supply that is extra used for hyperion charger if you still need one. 25.0 plus say 5.0 for shipping. I will go see what it is exactly as I have not used it in months.
                            *** Sorry, its a Novak black box good for only 5.0 amps. Sells for like 60.00 new but if you have a use for it my offer is open. Goodluck finding what you need. I guess thats why this one has been setting in the storage box:)
                            • old guy
                              • 710
                              Old Guy
