Titanium turn fins for "P" and "P" Spec Sport Hydro's
  • TRUCKPULL
    • 2971
    Titanium Turn Fins - New Design
    I have been making Titanium turn fins for "P" and "P" Spec Sport Hydro's for 3 years now.
    With the new speeds we are now achieving, some changes have been made to the design.
    To reduce the hull from climbing up on the fin at the speeds that we are running today with the Tenshock motors.
    The lead angle has been reduced from 30 degrees to 17 degrees.
    Also the machined edge has been increased from 5 1/2 degrees to 7 degrees making it longer by 1/4" to 21/32" long.
    I also added a curved - elongated hole for the break away bolt.
    The Titanium plate is 0.073" thick
    As you can see in the pictures, I have yet to put these in the hydraulic press. If anybody is interested in a straight fin
    (NOT Bent), please let me know as soon as possible.
    NEW Pricing-All in USD . My cost for the material, water jet cutting, hardware and shipping has all gone up.
    I now have "Q sizes fins and brackets with hardware also.
    P- fins -$70.00 shipped East of the Mississippi, Add $4.00 on the West side
    P- Brackets -$10.00 -with hardware -$12.00 Shipping with a fin.$3.00 on the east and $4.00 on the west
    Shipping without a fin $6.00 on the east and $8.00 on the west side
    Q- fins -$80.00 shipped East of the Mississippi, Add $4.00 on the West side
    Brackets -$12.00 - with hardware - $14.00 - Shipping with a fin. $3.00 on the east and $4.00 on the west
    Payments will be excepted at Pay-Pal, lgjaques69@gmail.com. F&F please.
    Pictures of my brackets and fins can be seen here; (posts #3 & #6)- https://forums.offshoreelectrics.com...-Sport-Hydro-s
    The fourth picture is the new one on the right compared to the older style.
    Pictures of the NEW "Q" fin can be seen below, Last picture on the right "P" on the left and "Q" on the right
    PS
    I forgot to mention that I made two of these fins a month ago, for testing purposes. the resalts were VERY GOOD!
  • TRUCKPULL
    • 2971
    I forgot to mention that I made two of these fins over a month ago, for testing purposes. the resalts were VERY GOOD.
    and work as designed.
    Larry
    • TRUCKPULL
      • 2971
      All bent and ready to go.
      Larry
      • eric113
        • Sep 2011
        • 327
        I probably will buy one. Just curious were the hole and slot on turn fin… made for a specific turn fin bracket? What is the screw size for the turn fin?
        • TRUCKPULL
          • 2971
          Sorry it took so long to reply, I just saw this.
          The round hole is 4mm. it is located 1/2" back from the front edge of the fin.
          The slotted hole is 1/8" wide and 1 and 7/16" to the rear of the round hole. The slot is arced from the radius center of the round hole, for adjustably.
          I will have brackets availably at the end of this week. Pictures to come.
          Larry
          • TRUCKPULL
            • 2971
            I have some of my brackets ready to go out.
            My turn fin bracket is 1/8" aluminum. in the pictures you will see three mounting bolts into the back of the sponson. I also use a 6/32" stainless threaded rod to connect the top rear of the fin to the body of the hull. This makes it a very strong mount. It is also adjustable by using the two lock nuts on either side of the fin bracket. After you have your rudder set straight, you can now adjust the fin to fine tune your hull to make it run straight.
            If you buy a fin - the bracket will be $8.00 USD shipping $2.00
            • TRUCKPULL
              • 2971
              Uppppppppppppdated
              • JoeGaracia
                • Jul 2024
                • 6
                I sent you an order. Do you still have some in stock?
                • TRUCKPULL
                  • 2971
                  Pictures of the NEW "Q" fin can be seen below, "P" on the left and "Q" on the right
