Himodel 200amp esc
  • Punisher 67
    Ignore list member #67
    • 1481
    Douggie I havent really pushed one to hard yet but when I get caught up I want to push one to the brink on a bench test and will certainly post results probably with a youtube video
    I really like it so far especialy not needing a pistix
    Necessity is the mother of invention.............
    • Jesse J
      scale FE enthusiast
      • 7241
      I posted my set up when I blew mine, but might as well again here for the record.
      I was running my Titan 29, 10XL, HM 200 (added water cooling to the fins on top), wire drive, Grimracer 4466 prop on 6S (5000mah). Time to meltdown was under 2 min. Top speed was 41 mph. I think Reddywatts said (according to FE Calc) I was pulling 167amps, probably more since I was tooling around instead of doing religious laps. Jeff I am sure you have read through this thread:
      http://forums.offshoreelectrics.com/...t=titan&page=2
      I am investing in an Eagle Tree to be able to quantify actual data.
      "Look good doin' it"
      See the fleet
      • Viking
        • Jul 2008
        • 133
        Hot ESC
        Jesse;
        I see your mistake and you know what it is or you wouldn't have mentioned it.
        The water cooling needs to be right on the mosfets. You need to remove the shrink wrap and the finned heatsink and put your water cooling right where the finned heat sink was.
        Don't forget that heat rises, mount the ESC so the water cooling is on top. The heat rises into the water cooling plate and is drawn away by the water. There was a photo on here or RR of a boat with a burnt ESC the guy had mounted the ESC so the water cooling plate was on the bottom. I think that was the only reason he cooked it.
        Viking
        That Viking www.How2RC.com PULSO
        Home made 36" DeepVee 50mph
        • Viking
          • Jul 2008
          • 133
          Hi Model 200
          I have been running the HiModel/Mystery 200Amp ESC all Season with no problem.
          My boat is pulling 150Amps according to my EagleTree logger. The ESC only gets comfortably warm, BUT I don't try to empty the batteries in one run, without checking how things are. Occasionally I have found my 4800mAh 3s lipos hotter than the ESC or the motor, running 6s on the boat.
          Maybe I should water cool the batteries too
          Viking
          • planezero
            • 94
            Originally posted by Viking View Post
            Jesse;
            So you left the soft (heat conducting) material between the FETs and the cooling plate ?
            I'm pondering to put the plates right on the FETs or leave the material there...
            • ReddyWatts
              • 1700
              Air cooled
              I am trying to air cool the inner Fets.
              ReddyWatts fleet photo
              • Jesse J
                scale FE enthusiast
                • 7241
                I put water cooling on the outside of the fins. I didn't even take off the shrink wrap. Since, I have removed it and the cooling plate and have a plan.
                See the fleet
                • Viking
                  • Jul 2008
                  • 133
                  White stuff
                  I removed the white stuff.
                  If you find the MosFets are not exactly flat and making perfect contact with the water cooling plate, you can even their contact surface by lapping them with emery cloth and a perfectly flat surface. Like a piece of heavy plate glass, or a machined tool table. Then use a little silicone heat transfer compound (the same stuff computer guys use when putting the heatsink on a CPU heatsink) on the MosFets before installing the cooling plate. I re wrapped the ESC and cooling with a piece of shrink wrap I got from Steven.
                  However I didn't use a simple cooling plate I used some brass sheeting and brass c channel to solder up a water tank 3/16" thick, just the correct size for the ESC. Drill a couple of holes in the end and solder in brass tubing for inlet and exhaust water connections.
                  I also used DP Epoxy to waterproof both of the printed circuit baords. The DP Epoxy is non conductive and safe for electronics, it is available from Steven.
                  Good Luck;
                  Viking
                  • Spot Me 2
                    • Jul 2008
                    • 769
                    PM sent.
                    MMGMMarine
                    RobertsonRacing
                    • Jesse J
                      scale FE enthusiast
                      • 7241
                      Viking, I like that idea. I have made a little "box" out of brass sheeting for my Turnigy 100A and it has worked great. I like the idea of water rushing over the hot surfaces as opposed to just a tube touching a plate. thanks for the explanation! I will try it for sure.
                      See the fleet
                      • ksm2001
                        • Jun 2007
                        • 377
                        Here is the thread on the HM 200 amp a while back with cooling plates
                        http://forums.offshoreelectrics.com/...ead.php?t=5924
                        Go to post #5 I added some pics of the HM 200 with cooling plates
                        • crrcboatz
                          • Jan 2009
                          • 914
                          the thread does not go that far, #51. It was something like 48 or so.
                          • ksm2001
                            • Jun 2007
                            • 377
                            post #5
                            • Eyekandyboats
                              • 1921
                              got it today Peter, thanks man, I love ya!!
                              EYEKANDYGRAPHICS
                              www.rclipos.com
                              • Punisher 67
                                • 1481
                                Glad to see that it arrived safe Taylor , give me a dingle on how it works for you
