5S 5000MAH 18.5 Volt Poly-RC LIPO's
  • Sparky-rc
    • Aug 2007
    • 282
    For sale 2 Poly-RC 5S 5000MAH 20 C Lithium Poly batteries. These have about 20 to 30 cycles on them and were always balanced. They come with Deans connectors, and a Hyperion balance jack. One is dipped in sealant for waterprofing, one is not. Only because that's what was in stock at the time of purchase. They are in excellent condition. These batteries cost well over $200 each. Both for $265.00 shipped USA ONLY
    Warning:
    - Use only with a charger designed for Lithium Polymer batteries.
    - Do not leave Lipo batteries unattended while charging.
    - Do not charge Lipo batteries near combustible materials.
    - Do not charge Lipo batteries at a rate higher than recommended charge rate.
    - Do not discharge Lipo batteries at a rate above the specified “C” rating.
    - Do not allow Lipo batteries wire leads to short circuit.
    - Do not allow Lipo batteries to to exceed 140° F at any time.
    - Improper charging or use of Lipo batteries may result in fire and/or serious bodily harm.
    - Do not expose Lipo batteries to water or moisture.
    - Store Lipo batteries in a secure place away from children and sources of heat.
    - If Lipo battery is involved in a crash inspect it for damage.
    - Do not use Lipo batteries if cells are damaged or swollen.
    - Recycle Lipo batteries, do not discard in trash.
    Disclaimer: Lithium Polymer batteries can be dangerous if used improperly. The seller is not responsible for accidents resulting from the use of these products. By purchasing these batteries you agree to these terms.
    Titan 29...GONE, team believer...GONE, mean machine...GONE
  • Sparky-rc
    • Aug 2007
    • 282
    In case the original pics didn't show up
    • Sparky-rc
      • Aug 2007
      • 282
      Sold pending payment
      • txboatpilot
        • Oct 2007
        • 1805
        M/Order has been sent for both packs..
        Thanks,
        Rich
        • Sparky-rc
          • Aug 2007
          • 282
          Sold.....Thank you
          • txboatpilot
            • Oct 2007
            • 1805
            Got the packs, charging them now.. I will give them a test run this afternoon!!
            Thanks,
            Rich
