HD motor mount for 4in rails with ESC mount
  • Quietlee
    • 162
    Sorry - no longer for sale. Found a use for it. Another bundle find. Looks unused. 25mm hole spacing for motor. 91mm overall length. Front and rear parts have recesses where the motor would fit. For some reason the front is 46mm diameter while the back recess is 50mm. Motor length of about 87mm should fit snug. $30 shipped in the lower 48. Paypal.
  • RaceMechaniX
    • 2825
    Maybe this was for a Castle 1717?
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • dasboata
      • Dec 2010
      • 3152
      Looks like plated steel but I doubt that ugg don't really see good aluminium look like that ???
      • CraigP
        • May 2017
        • 1464
        I believe it’s 7071 aluminum. I recommended one of these mounts to a friend building an 1/8 scale Blue Blaster. Putting a 56mm Leopard in. I never saw the mount in person, but he sent me pics and says the workmanship is really nice!
        • CraigP
          • May 2017
          • 1464
          I think it’s the same one...
          • Bp9145
            • Jan 2016
            • 1466
            Craig, that does look the same but it might look the same but it's the recess inside each end is in question as they are having two different diameters. . .perhaps it was custom made for a specific motor?
            • CraigP
              • May 2017
              • 1464
              Yes, I see the difference now... The one in the pic I posted is from Steve on the OSE site. It actually looks much better. The other one has some rough machining and I think you guys are right, it looks plated and it’s not anodizing, so it’s not aluminum. Man that’s got to have some weight on it! Perhaps zinc? Strange material selection... Aluminum is a no-brainer! The one I posted does have an upper tray for the ESC, it’s just not on in this pic. You can see the holes for it though...
              • CraigP
                • May 2017
                • 1464
                Is this heavy compared to what you’d expect for aluminum? It looks to have an unusual plating on it... we are trying to figure out what material it is made from.
                • Quietlee
                  • 162
                  Hadn't really thought about it. Not all that heavy, but I'll throw it on the scale when I get home. Magnet test too.
                  Sent from my LG-M210 using Tapatalk
                  • CraigP
                    • May 2017
                    • 1464
                    Good idea!
                    • dasboata
                      • Dec 2010
                      • 3152
                      Plated cast white metal is my guess now
                      • Quietlee
                        • 162
                        Aluminum, at least that's my thought. Can see some rough machining on it. Holes through it and the threads in other spots are smooth so it doesn't appear to be cast. Took a grinder to the bottom edge to make sure it wasn't plated. Comes in at a little over 4 oz.
                        Need to apologize to those who might have been considering buying it. I took out my old Neu 1521 and except for the wires out the back of the motor, it should be a perfect fit. Gonna keep this one for the P-mono build.
                        Another lighter mount is going to be posted shortly.
                        Have to blame this mix up on the cold meds.
                        • CraigP
                          • May 2017
                          • 1464
                          I don’t blame you, it’s a nice mount!
