Twin mean machine 2 - artr
  • TRUCKPULL
    • 2971
    I have my twin Mean Machine 2 for sale, The inside Transom and Hull have been reinforced, Sponsons have been Blueprinted with West Marine - Marine RX and all edges are sharp and flat.
    It could use a new paint job, some chips and marks in the paint but the hull is solid.
    It will come RTR except for Radio and batteries.
    This boat was built to Race in the "P" classes (Offshore, Cat-Sprint)
    For Offshore class (over 4 minute run time) the 90mm EDF Tacon 3674 2Y/4Pole 1700kv motors were picked because of there higher efficiency and Watt ratings.
    I did however upgrade the bearings with Boca Ceramic Hybrids. With two motors the Amp draw had to be kept below 65A each.
    With this setup I was able to run at 55MPH and turn like on rails.
    For Cat-Sprint (6 lap Oval)
    I have a pair of LBP 3674 3D/4 Pole 2200kv Motors with Left and Right hand water jackets from HRC
    With this setup it runs 60MPH on rails.
    These Motors will be offered to the buyer at an extra cost before I sell them to anyone else.
    With this hull I have found that running the props outbound it preformed a lot better for racing.
    I also had to extend the rudder so that the leading edge was behind the props.
    This was done because this hull does NOT have a overhang at the rear.
    This hull is only 29 1/2" long, so it runs the same as a 32" or longer hull that has a overhang. it also has a wider stance (5 5/8" between the sponsons) which gives it more stability at speed and in the turns.
    To see what all is included see the parts list in the pictures.
    I will relist this boat.
    Larry
  • TRUCKPULL
    • 2971
    Here are some before and after pictures of the sponson blueprinting that I did.
    • TRUCKPULL
      • 2971
      More blue printing.
      • TRUCKPULL
        • 2971
        I will relist
        • TRUCKPULL
          • 2971
          I forgot to specify that this boat is setup for 4S2P
          ESC's are also wired so each ESC see's 4S2P
          Larry
