Icharger 206b with 24v power supply
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    And parallel charge board.
    Used only a few times. Comes with everything it came with in box my cat chewed up.
    Power supply built by Joel (rockstar)
    Parallel board just solder your connectors on
    175 shipped inside the USA for everything.
    Sold!!!
  • runzwithsizorz
    • Jan 2009
    • 856
    The 206B charger is designed for charging 1S-6S packs at up to a 20 amp charge rate, while also giving you useful tools such as measuring the internal resistance of your batteries, or safely and easily discharging packs for storage.
    Specifications:
    Maximum charge power capacity: 300W (at >18V)
    Charge current range: 0.05-20.0A
    Discharge current range: 0.05-20.0A
    Input voltage range: 10-28V DC
    Maximum discharge power capacity: 20W
    Maximum external discharge power capacity: 500W at 25V/20A
    Current drain for balancing: 350mA
    Balance accuracy: <10mV
    LiPo/LiIo/LiFe: 1-6 series (up to 8S LiFe in non-balanced mode)
    NiCd/NiMH battery cell count: 1-17 series
    Pb battery cell count: 1-12 series (2-24V)
    Battery setup memories: 10
    Intelligent temperature control: Yes
    PC Connectivity: USB port
    Weight: 315 g
    Dimensions (LxWxD): 134x83x25 mm
      Make Total Destroy
      • Mar 2014
      • 1952
      Hey dude I hadn't even seen you had posted that.
      Thanks. Were you interested?
      • jim82
        • Jan 2013
        • 1358
        If I was in need for a charger combo I would hop on this its
        good deal great chargers
          Make Total Destroy
          • Mar 2014
          • 1952
          TTT
            • 5660
            Originally posted by Luck as a Constant View Post
            TTT
            How much shipped to 91006?
              Make Total Destroy
              • Mar 2014
              • 1952
              Oh, that's just to show you guys where the money will be going lol
              • shua
                • Apr 2015
                • 479
                Luck, would you be interested in selling that para board separatly?
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  Nah bro it's part of the package.
                  • shua
                    • Apr 2015
                    • 479
                    Aight, no worries man. Good luck with the sale.
                    These are Awesome chargers folks!
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      Thanks. Progressive rc has them for 19 bucks bro.
                      Someone will be very happy with this charger. It did my 6s 5000 mah pack in less than 15 minutes per pack. Two in a half hour or less
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        150 shipped
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          After 4th bump
                          • nichismo
                            • Feb 2015
                            • 393
                            Hey im in the middle of building my first boat and im entirely new to RC, would you be able to provide me a little instructions with this? Im going to be charging a pair of 4s 5500mah packs and a pair of 5s 4800mah packs from Revolectrix. If so, ill take it.
                            BIG BOY HYDROPLANES----My first RC boat and build project to boot: (and more content in my profile gallery!) ---- http://forums.offshoreelectrics.com/...proposed-setup
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              Hey dude, it doesn't come with instructions but it's pretty easy to use.
                              Youtube probably has some instructions on how to use it.
                              Lmk if you find something and want it.
