Up for sale is a very well refined and gone through V3 Blackjack 29 this is the newest and latest version with the 2000kv motor and 120 ESC. It has very low run time , I spent more time basically redoing all the stuff from the factory and replacing it with high quality parts than running it.
First off I cut out the crazy long factory motor to esc wires that were ridiculously long, I directly soldered them together with the perfect length. I am crazy about getting my solder jobs just about as perfect as possible.
OSE custom made heavy duty drive cable and shaft.
OSE drive strut with Teflon bearings
Ballooned the receiver so that it's safe from any water or moisture.
Sharpened, Balanced polished and cut down Prather S225 Stainless steel prop,
Larger diameter cooling lines throughout, allowing better flow and cooling.
Custom reinforced shaft support, no more flexing or twisting! Eliminates broken drive shafts! Best mod hands down! Made a huge difference!
Sealed shaft and strut exits so the hull stays perfectly dry every time!
$390.00 takes it
I would give anything to start with this awesome boat this way! So much time invested on getting it reliable and RIGHT! I've spent way more money than I ever wanted to spend but I had to get it perfect.
Has scratch or two but absolutely nothing major, it has very little use and is just an absolute blast to drive! It handles really really well! Sad to see it go!
I'm only selling it to move up to bigger boats.
$390.00 takes it
