Suppo HV (6S-10S) 80-100 amp esc's. Both tested and running fine. Tested on 6S using a spark suppressor as I recommend you also add or use.
Both have extra DP270 epoxy on the boards, the blue shrinked one has the cooling plate glued on with Thermal Silicone electrical adhesive and the other I is heat shrunk clear and has black front,These were made for helis and had water cooling plates put on them to use for boats or can remove plates and use for heli i would assume got these here awhile back dont need them and didnt use since i got them
80.00 shipped for both of them to lower 48 u.s.
