Hey Guys,
I am slowly cutting back on my inventory so much of this stuff needs to go!
Both of these controllers started off as Aircraft controllers that I personally converted to water cooled. The cooling tubes/blocks were adhered using the Artic Silver Thermal Epoxy. These were only used at the nationals held in MI this year. Neither controller had anything more than 4S and 2200Kv hooked up to them. Very low duty cycles and NOT stressful set ups at all!
#1 – has the cooling tubes epoxied directly to the bus bars on both sides of the controller. While it took some creative bending of the tubes, it is a “smaller” package than #2. Price for #1 is $165 shipped in the US
#2 – has purposed machined bars on both sides of the controller. This was done to maximize the surface area for cooling. On each bar there was a “U” channel machined again to maximize surface area for cooling. Original box and paperwork included. Price for #2 is $195 shipped in the US
EDIT - I should also mention both of these are set up for 2P battery set ups. The connection is wound with solid copper wire and then soldered. This eliminates the need for an additional connector when using an "Y" adapter.
Later,
Mike
Later,
Mike
