ESC's-big and small!
  • kevinpratt823
    • Aug 2012
    • 1462
    SF240HV Pro- $150 shipped-see below, buy at your own risk, may need work.
    I have used this as a backup in a few boats, big and small. Wires were stripped close to ESC where I had a Cap bank, switch is glued to face of unit but would prob pry right off. Label is peeled off, and she may be a touch dirty, but I just bench tested it again with a 5s and a 1577/1Y and all is well http://www.offshoreelectrics.com/pro...ef-HBC0240L-CW
    Edit: Upon looking close at the pics of the SF240HV, I noticed a tiny whisp of a white spot on the inside of the heat shrink, so I am not sure I am comfortable selling the unit. I did have a motor failure early this year, and the ESC worked fine after, but I wonder if a cap has been compromised or something.
    Edit#2: I trimmed the shrink and dug away at the rubberized coating in the area that I noticed the spot, and found that one of the leads from a capacitor has parted. If anybody wants it for $150 shipped you can take it at your own risk, otherwise it sits on the shelf as a backup. I would likely be running an additional cap bank anyway, but maybe I'll do a little dissection project on it this winter and replace the cap and inspect the inside.
    Seaking 120(V2?)--------SOLD-----$40 shipped .----SOLD-------
    Hasn't seen a ton of use, but has been kicking around a while. Previously I had covered it with plasti-dip, but I had peeled it off because I was going to sell it last year and it looked messy, still has some on one end. Has a single 67c/470uf cap soldered on and clear shrink on whole unit, and 8mm bullets on both ends, red rx wire is pulled frome plug because I used external BEC, but can be put back in. Just bench tested with a 5s and 1527/1Y and all is well.
    Turnigy Marine 35a 2-3s ESC and Barbwire 20a ESC-both for $45 shipped.----SOLD--------
    Turnigy is brand new, has 4mm bullets for motor, batt wires never soldered, I used one in my barbwire and it worked well.
    Barbwire ESC is slightly used, and I believe this was actually the 25 amp replacement upgrade they sent me when they had problems initially, but I can't be positive because I have another in a boat(both still say 20a), however this one was in a box with the label that said 25a, assume it's only 20a but more than likely(95%) this is the 25a. I had 2 of the Turnigy's, and IIRC I took this out of a boat just to try one of the Turnigys, which worked great so I left it.
    Shipping is 48 states, not looking for "offers" at this time. Items are also posted on another forum. Thanks for looking.
    My private off road rc track
  • kevinpratt823
    • Aug 2012
    • 1462
    Sk120, T35, and Barbwire ESC's
      I'll take the seaking 120
      • Rocstar
        Joel Mertz
        • 1536
        Kevin, I'll take the T-35a and Atomik 20a.
        • RandyatBBY
          • 3943
          I am interested in the 240HV do you have a picture? I am on the coumpter off and on today. I will answer asap after you answer me. I wanzt to see how short the wires are.
          Randy
          BBY Racing
          • kevinpratt823
            • Aug 2012
            • 1462
            The pics are in the first post, but for some reason it only showed as an attachment link, I'll see if I can get them up.....wires are full length, don't think I ever shortened them, at least a few inches.
            Edit: Upon looking close at the pics of the SF240HV, I noticed a tiny whisp of a white spot on the inside of the heat shrink(it wiped right off), so I am not sure I am comfortable selling the unit. I did have a motor failure early this year, and the ESC worked fine after, but I wonder if a something has been compromised. It ran smooth on the bench, but I should probably just keep it as my back up unless somebody wants to take the risk or repair it for $150 shipped.
            • TheShaughnessy
              • 1461
              that was fast, been looking for a good deal on a 120, early bird gets the work.
              • RandyatBBY
                • 3943
                No Problem
                Randy
                BBY Racing
                • kevinpratt823
                  • Aug 2012
                  • 1462
                  No Problem
                  Not sure if you saw my edit in the first post, but if anybody wants to take the risk, or repair yourself, I'll sell it for $150 shipped as is.
                    Hey bud, you can have it. I was getting it as a spare. I have ended up buying a new one a couple weeks ago.....you need it, it's yours.
                    • TheShaughnessy
                      • 1461
                      Thanks I'm gonna go ahead and take you up on that! Ill take it kevinpratt823
