2 Schultz Chargers with 8mm bullets and 12 volt 55 amp server power supply
  • jcald2000
    • 768
    $125.00 for all plus shipping. Schultz manuals included.
    No Private messages, all correspondence must be on the board.
    This ad is also posted on other boards.
  • leybold12
    • 35
    What version of software are these? I need to charge LiFePO4 cells. Thanks.
    • jcald2000
      • 768
      • leybold12
        • 35
        Sorry, too much money to get upgraded. $70 per unit plus round trip shipping to Germany.
        Good luck selling.
        • jcald2000
          • 768
          Thanks for looking, I only use Lipos (Dinogy) so that is all I have charged with this system.
          I know guys were charging them using the 3 NiCad or nimh setting (3.6 volts) on them, I understand.
          On a side note, I guess these are receiver batteries since they typically have IR of 30 vs 2 or below for Dinogy Lipos.
          Please don't try to use them for power batteries!
          • leybold12
            • 35
            These should be great for Lipos up to 10 cells with the proper balance board. Yours includes the balance boards for up to 6s (though two can be daisy chained to charge more cells). My two Sclulze Chamaleon isl 330 D chargers have software and hardware revision 8.41. They charge my 10s LiFePO4 fine with the correct balancing board. I could copy my eprom code to your eproms but these was a hardware revision also which might be hard to reverse engineer to figure it out.
            • goferit
              • Aug 2014
              • 10
              Have absolutely nothing to start with. Looking at the rigger you posted, but want the rest of necessary charger, battery and other things to be ready to go. Will this charger be what I need for the rigger? Hope to get all I need with some help here.
              • jcald2000
                • 768
                Yes, the charging system will charge 2 - 2,3,4,5, or 6s LiPo batteries, at the same time, form 120 volts at home or your car battery elsewhere.
                Let me know what batteries you are going to run and I will set it up for you so you only have to plug the batteries in and push a button to charge.
                Welcome to the sport!
                • goferit
                  • Aug 2014
                  • 10
                  Maybe you could help me out with the decision on batteries? You say 4s or 5s will run your rigger, so it sounds great. Will you take $110 and if you ship it with the rigger boat?
                  • goferit
                    • Aug 2014
                    • 10
                    Duplicated
                    • jcald2000
                      • 768
                      See boat post!
                      • jcald2000
                        • 768
                        Still for sale!
                        • jcald2000
                          • 768
                          Bump
