I used this once and it does scream but isn't the right motor for racing so it's not going into any of my other boats. I cut the ends off because they were cheap connectors anyway. Asking $35 odo
2900Kv Brushless Motor: WM [PRB3911]
Tags: None
Has the enamel been removed from the remaining wire? Usually when you cut off the connectors like that there is only wire left covered in hard to remove enamel.
No I haven't removed anything but the plugs, it's just like you see it. I really didn't have chance to slip them off cause I wrapped it up right after I took these pics.
Ok I was able to pull one of the covers off and put it back on, I'm not sure what tinning is? It's bare wire under the sheaths, I'm not seeing any other covering.
As I said, the work involved to remove the enamel from the remaining wire is huge.
If you cannot confirm the feasibility of tinning new connectors, would you mind, please, selling me the motor with 5.5 male bullet connectors?
If you cannot, I will step aside from the deal......and sorry if I make you loose your time.
Christian.
I don't think there will be a problem but yeah if there's a problem I'll refund you. I'll post a new pic of them
