5694 SSS HOR-TP Power motor & cooler Cheap
    Too much motor for me. I ran this 4 times in my 40" Carbon Kevlar mono, that's it. It is 1200kv, and can take almost 300amps max. HOR
    Second run I lit up 6s2p inside and the motor and esc survived. Replaced bearings after total motor tear down & clean. 3rd run was the best, 6 minutes and no heat with new 6s2p dinogy 65C batts. 4th and last run I burned up the AS240... it could only take so much. Sent my batts for reconfiguration to 4S + 2S packs so, I'm done with the 40" hull and 6S boats.
    The motor has been cleaned out again, bearings are still great (better than stock). No connectors, just as you see it in pics.
    It has been bench tested and the idle current is fine compared to HOR web site, where it came from.
    This motor is a horse!! It is very hard to kill as you can see.
    It was not the motors fault for the fireworks, just me with either cheap cells and too much prop (Prather 240) for 4 min offshore...
    Price: $75 shipped in Canada or USA. It's heavy, going to cost me at least $20 to ship it. My loss yours to gain. Great motor for a SAW cat or mono if you can afford the esc to run it. Yep, this puppy is a monster...
    • 7512
    Put me first in line ray...can you give me the dimensions L+ D of the can....might fit something I have...we can arrange a pickup/delivery if it will fit.
      56mmD x 94mmL, 6- 4mm bolt holes.
        • 7512
        Should fit...whats the shaft size?
        Has it been appropriately aired out since the last episode?
        Don't want to smell up my workshop!
        Hows $65 sound if no shipping required?
          It's been dunked & soaked in Isopropyl, then coated with corrosion block. I had alcohol right there. That's fair enough John. I may try an outrunner in the mono or 8S1P but, propped waaay down. Leave it for a retrieval boat or sumtin..
            • 7512
            Ok Ray...consider it sold...you want cash or PP?
              Aaahhh, too late for paypal I guess... Cash works...
                • 7512
                I'll PP you if you want, just PM me your info.
