BBY Zephyr - Carbon/Kevlar - SAW/Oval Scale (Sport) Hydro - IMPBA and NAMBA legal
This topic is closed.
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3312
    SOLD
    Up for sale is my IMPBA legal SAW Sport Hydro and is also suitable for oval use. This model will be sold as hull, hatch, watercooled motor mount, antenna mount, and water inlet only. If you need other hardware, that could be arranged, but at an additional cost.
    Features and Description:
    • For lightweight purposes, this hull was constructed using the plastic shell and fully lined with Carbon/Kevlar fiber weave on the top, bottom, and hatch (the blue seen in the pictures is Kevlar).
      • NOTE: This is the version of the BBY Zephyr that features the redesigned top to reduce lift at higher speeds. In other words, this is the latest generation, not the original.
      • Sponson areas are reinforced with two layers thick at 45 degrees.
      • During construction, thin CA was flowed across the CF/Kevlar material, partially melting the plastic for a chemical bond that cannot be removed or peeled without extreme effort.
      • A thin layer of finishing epoxy was brushed over the bottom where components sit.
    • Entire hull has been reinforced with Carbon rod for bracing purposes. The model is very stiff with very minimal flexing.
      • The motor mount was modified to tie directly into Carbon rod bracing. This means that when running motors with higher torque, the load is spread across the entire bottom of the boat vice other methods where the bottom may flex.
    • Features an OSE watercooled motor mount to accommodate 380 to 540 size motors. I have run larger motors in this hull with diameters exceeding 36mm, but must be compatible with standard 540 spacing for the screws.
    • Transom is doubled with both Carbon/Kevlar fabric and high impact Lexan. This allows for extreme stress without being brittle and fracturing.
    • Setup to run .078 wire drive. If you need one, I can supply one at an additional cost. I never broke a wire, even at high RPMs (in excess of 50,000) in this model.
      • Stuffing tube for wire drive features double wall construction (tubing inside tubing for maximum strength).
    • Driveline is offset to allow for larger diameter props and to avoid prop walk.
    • Features ride pads that reduce planing surface for higher speeds, but does not negatively affect lower speed applications.
    • Model gets on plane without any plowing, even from a dead stop, even with the CG pushed forward.
    • Since this model was intended for SAW applications, a turn fin was never installed. However, the mounting area on the starboard side has been reinforced to accommodate should you chose to run this model in an oval application.
    • Measures just under 27" in length.
    • All decals are vinyl and can be easily peeled off if you choose to do so.
    • No electronics were burnt in the model and does not have the associated odor.
    • The model has not sustained any damage since construction.
    I can help the buyer with electronics and hardware suggestions, but prefer not to discuss in an open forum. I will also offer support regarding setup as it relates to prop choices and strut depth based on your particular setup and application to the best of my abilities.
    Sale Price is SOLD to the lower 48, firm. Please see other payment and shipping details below.
    • Payment is via Paypal only.
    • The first person that posts that they will buy this model within this thread will be honored.Simply asking a question does not constitute a commitment to purchase. No PMs with intent to purchase will be honored.
    • Paypal info will be provided via PM for security reasons.
    • No other payment terms or trades will be considered at this time.
    • Insured shipping is included to the lower 48 states.
    • I will ship to other locations, but shipment the buyer is responsible for excess shipping costs including any duty or other export fees.
    • For a shipping quote to other locations outside the lower 48 states, please provide a shipping address via PM. I will allow you to put a temporary hold on this model by stating that you will purchase, pending shipping quote to locations other than the lower 48 states.
    Should there be any questions regarding this sale, please post them in this thread and I'll be happy to answer. Please, if you are not truly interested in purchasing this model, please do not post arbitrary or extraneous questions/comments just for your own interest. Thank you.
  • Jtun5608
    • 22
    Interested, where in va are you? I am in Richmond
    • Meniscus
      • Jul 2008
      • 3312
      I'm in Chesapeake, VA.
      • Meniscus
        • Jul 2008
        • 3312
        Still for sale. Price is now $150 shipped to lower 48.
          • 7512
          Send a PM to Robert (LiPo Power on the forum)...His UL-1 was put out to pasture this season and needs a good hull to use the hardware and electronics in....
          • LiPo Power
            DJI Drone Advanced Pilot
            • 3678
            I am next in line if there is no buyer next couple of days.
            I have product sold and money transfer is pending.
            My customer has no PP set up and I need to wait little longer.
            Also please let me know the cost of shipping
            to Mississauga Ontario Canada L5B 4B9...
            Thanks
            Robert
            Canada
            • BILL OXIDEAN
              • Sep 2008
              • 1561
              I can vouch that the Zephyr 27 once held the NAMBA N-2 sport hydro SAW record at 70mph
              It also has placed top 3 in N-2 sport hydro (NAMBA) at the nationals 3 consecutive years.
              Same boat led our district high points in LSH 3 consecutive years.
              Fast little sport hydro, predictable, almost No fin slippage in the corners like its got fingers (with Randy's fin on it)
              I've seen Meniscus boat in person as well. Not a worked over, run to death hull, plenty of life in it for its new owner.
              150 shipped with hardware? Someone's gonna' scoop it..
              • Meniscus
                • Jul 2008
                • 3312
                Thanks. That's without hardware, just to clarify. I've got a lot of work into the build on this one.
                • LiPo Power
                  • 3678
                  Hi, I am just waiting on you to check the shipping and ready for it if reasonable.
                  Let me know
                  Robert
                  Canada
                  • Meniscus
                    • Jul 2008
                    • 3312
                    Model sold, pending payment.
                    • LiPo Power
                      • 3678
                      Money sent, please let me know when shipped, Thanks.
                      Robert
                      Canada
                      • LiPo Power
                        • 3678
                        Was the boat shipped yet?
                        Canada
                        • Meniscus
                          • Jul 2008
                          • 3312
                          Yes, shipped. I'll let you know tomorrow what the expected arrival date is.
                          • LiPo Power
                            • 3678
                            Thank You and Merry Christmas to me....
                            Canada
                            • LiPo Power
                              • 3678
                              Boat received in proper condition, Thank You.
                              http://forums.offshoreelectrics.com/...999#post472999
                              Canada
