FighterCat 16s-300a controller
  • HTVboats
    • 802
    ESC shipped USPS priority. There is a small female bullet negative lead on the esc and the male lead that came with it for a spark arrestor. I didn't use it but it would be easy to solder a resistor and a simple alligator clip to bridge to the negative (male) battery connector then remove as you made the bullet connection.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    • runzwithsizorz
      • Jan 2009
      • 856
      Package arrived, and all seems in order. In yours pics, I did not see the male lead which contains the resistor. glad it's there now.
      Thankz Todd
      • HTVboats
        • 802
        Recieved your package also. I forgot I had that lead. Not sure if it is a resistor so measure it with an ohmeter.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • runzwithsizorz
          • Jan 2009
          • 856
          Mic
          You can see the outline of a resistor under the wire shrink. But since it is on the controller side, without peeling back the shrink there is no way of testing it. However, since it is stock from
          Fightercat, one would assume it would be close to the correct ohm's. The resistor on my Fightercat 8s 200amp is on the battery side, and is 10.5 ohm's
          I know you said that you didn't use a spark arrestor, but I'll just leave these links here, in case you are interested. Cheers Todd
          http://forums.offshoreelectrics.com/...2%20Calculator
          http://forums.offshoreelectrics.com/...maritimo/page3
