U-Build Delta Force 35" Pirate Package
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1097
    Ready to Build
    I put this set up together after a years trial and error (lot's of them) with another hull and the resulting package is how I was planning on building "my" ideal set up. If you are interested in the package I'll be happy to chat about the layout and hardware ideas that I had but I'm sure it'll be easy enough to sort out with a little thread reading. This Package has cost over $950 to get here to Australia but I will sell the package for much less, read below.
    Package Includes
    1x Delta Force 35" Pirate mono hull - New, polished
    1x 34"(850mm)x20"(510mm) Carbon / Kevlar cloth
    1x 12"(300mm)x4" (100mm)x 2mm Carbon sheet
    1x Speedmaster 40 Rudder Assy. with 2 1/4" set back and dual water pick up blade and all hardware
    1x 4-40 push rod, 1x Du-Bro HD 4-40 E/Z connector #490, 1x 2pk Joysway waterproof boots
    1x Speedmaster 1.5"x1.5" Adjustable trim tabs, 2 pairs
    1x Large turn fins -OSE 80066
    1x Speedmaster 3/16(.187) Stinger drive assy.- SPDSD-2140
    1x 12"(305mm) 9/32 K&S brass tube
    1x 24"(610mm) Octura teflon tube to suit 3/16(.187) flex- oct187t-24
    1x 24"(610mm) Hughey 3/16(.187) flex shaft- b6664
    1x Octura Coupler 5mm - 3/16(.187)
    1x Octura 3/16 drive dog- oc6dm-3/8" o.d
    1x Dasboata balanced, sharpened and cupped Octura X445 prop- New with some decals
    1x Nylon lock nut, 1x brass bullet nut to suit 3/16 shaft
    1x 5mm Thrust bearing
    1x "Williams" motor mount, front section only, you can support the rear with carbon/aluminium
    1x Leopard Hobby brushless motor, 4080 1600kv, 8mm gold connectors supplied
    1x Leopard 70mm water cooling can to suit motor
    1x Turnigy marine 180 amp ESC fitted with 8mm gold connectors, extra 3x Rubycon 35v 1000uf caps
    1x 20" 10mm Turnigy heat shrink, red and 20" of black
    1x 4pk Great Planes large fuel line clamps
    1x 33"(840mm) Large silicon water tube
    2x Large OSE water outlets
    1x Hatch lift nut, 13x OSE decals
    1x PVC boat stand- used
    All this for only $700au delivered Australia wide*
    *International shipping will have to be discussed.
    "Gimmy Toyz for FUN"
  • millzee
    Ozzie Bloke
    • Nov 2010
    • 1097
    here's a few more pic's
    Just waiting for your address
    • technic11
      • 15
      wish you were in Canada mate
      best of luck
      • millzee
        Ozzie Bloke
        • Nov 2010
        • 1097
        I'm sure we could work out a deal on the shipping!!
        hours of building and years of fun on the water, just add time and money.
        • technic11
          • 15
          If things change let me know okay mate
          • millzee
            Ozzie Bloke
            • Nov 2010
            • 1097
            $50 Off If shipped in Australia
            • millzee
              Ozzie Bloke
              • Nov 2010
              • 1097
              Package no longer available, Please close this sales thread, thanks.
