Drive hardware
  • Basstronics
    • 2384
    Drive hardware
    I got a little bit of hardware I dont see a use for so its here.
    1) $20 3/16" propshaft. The strut and the rudder are stainless steel. The brackets are aluminum. This is someones home made hardware that is actually pretty nice. The stainless stuff is heavy as expected. This hardw2are was on the back of a Climate Blizzard. I switched it out for Fullers I had laying around.
    2) $10 1/8" propshaft. Small strut assembly. Thick aluminum bracket and strut. Has a brass bushing not lead teflon. This is reamed (by me) @ .125" and is SMOOTH. .195 ID on the cone for brass stuffing tube.
  • Basstronics
    • 2384
    3) $10 1/8" propshaft. This is lighter strut. Has lead teflon bearing. 3/16" drilled thru for brass stuffing tube.
    Sorry for the crappy pictures, its a crappy camera! (lost my good one). All prices shipped in US. The 1/8" struts are brand new never ran but may have been mounted.
    • Basstronics
      • 2384
      4) $15- 3/16" stinger- like those found on pursuits. I upgraded to Speedmaster so no longer needed. Used for approximately 2 minutes before my boat flipped and ripped out a bunch of epoxied down things...
      • Basstronics
        • 2384
        Bump
        Winters coming, grab some hardware for that build on the cheap!
          Hey,
          Do you have any bolts & nuts for the 3/16 stinger for mounting ?
          • Basstronics
            • 2384
            What length bolts?
            I have some bolts and nuts & washers. I think i have 12mm length bolts?
              I will buy the stinger,
              If you have mounting bolts & nuts to go with it.
              12mm is a little short I think.
              • Basstronics
                • 2384
                I found some 16mm.
                With nut and washer gives you .3" between for thickness of transom. I would think that should be enough?
                  Deal,
                  Thanks,
                  Send me your paypal please.
                  I need to get some hardware supplies in and epoxies to.
